Baseboard Shoe - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-31-2011, 05:58 PM   #1
Rewards Points: 208
Baseboard Shoe
does removing and replacing the shoe on baseboard molding damage the baseboard?
Scully is offline   Reply With Quote
Old 12-31-2011, 06:15 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 404
It can if the right tool isn't used or a person who don't know how.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 12-31-2011, 06:18 PM   #3
Rewards Points: 208
how would you remove the shoe without damaging the baseboard?
Old 12-31-2011, 06:26 PM   #4
Rewards Points: 13,750
First you have to cut the paint line so it does not peel the paint up the base.
I then use a puddy knife tapped between the base and the 1/4 round once the joit open up use a flat bar or better yet a trim bar (it's thinner) to pry it away from the base. If you use a flat bar use the curved part not the straight end. Insert the bar and turn it side ways. If you try and lift it you will dent the baseboard.
Once it's off use a pair of channel lock to pull the nails out from the back side.
BigJim (12-31-2011)
Old 12-31-2011, 08:09 PM   #5
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,214
joe hit the nail on the head. however if the trim is really old and dry it doesnt always want to come off without any casualties, more often than not in really old homes we dont bother trying to save old trim that we remove.. either we install all new or i mill up new trim in the shop that matches the old
woodworkbykirk is offline   Reply With Quote
Problem with 240V Elect Baseboard Heater JRHP Electrical 4 10-04-2010 09:30 AM
Laminate flooring / baseboard gap question willy0314 Flooring 0 08-07-2010 09:48 PM
Partial hydronic baseboard to radient floor conversion Jeepsail HVAC 4 01-17-2010 04:47 PM
Baseboard dilema Allyson Flooring 5 09-04-2009 08:30 AM
How to create a curved wooden base shoe? hayzen Carpentry 3 07-28-2009 03:29 PM
