Baseboard Nailing - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-29-2011, 02:32 PM   #1
Rewards Points: 1,062
Question
baseboard nailing
can i nail baseboard with regular trim nails ? because i have a nailer and would like to avoid doing it by hand.
Old 01-29-2011, 02:46 PM   #2
Experienced
Jackofall1's Avatar
Regular trim nails? as opposed to brabs?
I can't think of a reason why not, other than it will probably leave a larger hole which may need to be filled. You might want to be careful about wiring if you are using say 2" or 2-1/2" nails.
The 1/4 round is a different story if you are using that. The bigger nails may present a problem, not to sure on that one.
The Following User Says Thank You to Jackofall1 For This Useful Post:
amakarevic (01-29-2011)
Old 01-29-2011, 02:48 PM   #3
i think my trim nailer can do 1.5", not sure
Old 01-29-2011, 02:49 PM   #4
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
1-1/2" is really not long enough....but close
3/4" base +1/2"drywall = 1-1/4"
That only leaves 1/4" into your framing......
5/8" base leaves 3/8" ...........closer but not great.......
Last edited by tcleve4911; 01-29-2011 at 02:53 PM. Reason: Poster clarified "regular"
tcleve4911 is offline   Reply With Quote
The Following User Says Thank You to tcleve4911 For This Useful Post:
Willie T (01-29-2011)
Old 01-29-2011, 02:53 PM   #5
Originally Posted by tcleve4911 View Post
Please describe a "regular" trim nail?
Otherwise that's exactly what you install trim with........a trim nail....
Not sure about the question.....
i meant is there a special baseboard nail for baseboard installation.
Old 01-29-2011, 02:55 PM   #6
Question
also, do you know if it is possible to tuck new carpet underneath already installed baseboard ? i would imagine it would be easier to first install carpet and then baseboard but is it possible to do it the other way around ?
Old 01-29-2011, 02:56 PM   #7
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Have you installed the BB yet?
Old 01-29-2011, 03:00 PM   #8
no sir. the problem is, i am not ready to recarpet but i would like to replace the BB and paint.
Old 01-29-2011, 03:06 PM   #9
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Great!!! you are right on track.
Typically you hold your baseboard up off the floor 1/2"
Prime and paint 2 coats. Be ready for a little touch up after the carpet guys get through banging the carpet in while being careful not to get paint on the new carpet.
The Following 2 Users Say Thank You to tcleve4911 For This Useful Post:
amakarevic (01-29-2011), Willie T (01-29-2011)
Old 01-29-2011, 03:09 PM   #10
Question
but there is old carpet already. so how much above, if any should i be off the existing carpet ?
Old 01-29-2011, 03:16 PM   #11
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
don't know, don't care ......because it could be a different thickness than your new carpet.
Pull a piece of the carpet back and measure 1/2" up off the sub floor.
I like to take small 1/2" scraps and set those on the subfloor and set my new baseboard on top of that and nail it off. No measuring.....
Old 01-29-2011, 03:29 PM   #12
Question
i guess it wouldn't matter so much if i were to go with molding in the bottom where the BB joins the carpet, which would seal any gap left for grace spacing. but i'm a minimalist and trying not to have the extra molding to clutter the view, i.e. the BB fitting right over top of the carpet.
on a separate note, do you think maple 1x6 will do OK as baseboard. i dislike grooves or molding that normally marketed BB material comes with. i want something 100% simple that couldn't be simpler.
Old 01-29-2011, 03:42 PM   #13
Old School
Willie T's Avatar
The carpet guys will tuck the carpet up under your BB with a hook knife. They are used to this, and prefer it this way.
As for nails, it is best to set all of them (with a pretty large nail set). Not only do some guns do a lousy job of setting the nails, but also the tiny, tiny holes they leave are not sufficiently deep nor wide enough to really receive and hold spackling properly. (This assumes you are going to be painting the BB.)
Willie T
Old 01-29-2011, 03:48 PM   #14
Old School
Willie T's Avatar
Have you noticed that baseboard is kind of hollow on the back side? This is to help it pass over wall irregularities. And it is also why just using flat 1 x is not recommended.
Willie T
Old 01-29-2011, 05:25 PM   #15
Willie is right but if you're painting it, you can use caulk to seal any gaps between the base and the wall
mrgins is offline   Reply With Quote
Problem with 240V Elect Baseboard Heater JRHP Electrical 4 10-04-2010 09:30 AM
Laminate flooring / baseboard gap question willy0314 Flooring 0 08-07-2010 09:48 PM
nailing stain grade baseboard jeffergj Carpentry 6 04-01-2010 09:40 PM
Partial hydronic baseboard to radient floor conversion Jeepsail HVAC 4 01-17-2010 04:47 PM
Baseboard dilema Allyson Flooring 5 09-04-2009 08:30 AM
