Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-17-2011, 08:44 PM   #16
journeyman carpenter
woodworkbykirk's Avatar
Baseboard moulding
how thick is the baseboard? if its 3/8 pine you should be fine, the nail has to go through the base, 1/2" drywall or up to 7/8 if its plaster and then into the studs. when i install baseboard i use a nailer, as stated about how base takes abuse i use a 16 gauge because of its extra holding power and use 2" nails.
woodworkbykirk is offline   Reply With Quote
Problem with 240V Elect Baseboard Heater JRHP Electrical 4 10-04-2010 10:30 AM
Laminate flooring / baseboard gap question willy0314 Flooring 0 08-07-2010 10:48 PM
Door Moulding Idea Help Vibber Carpentry 4 06-01-2010 08:51 AM
Baseboard dilema Allyson Flooring 5 09-04-2009 09:30 AM
Baseboard moulding taller than air registers interplexr Remodeling 8 04-03-2009 07:24 AM
