Baseboard Mitres / MDF - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-25-2009, 10:56 AM   #16
Old School
Willie T's Avatar
Here's how it works. These plastic tape tips, or ends, are the greatest!
http://www.leevalley.com/wood/page.a...66&cat=1,43513
BTW... The reason your European friend was so fast:
You only have to make ONE adjustment (although, until you develop some confidence in the method, you SHOULD double check both diagonals. As I ALWAYS warn, your calculations could be off. Checking measurements is always cheaper than writing another check for more material.)
You simply divide the difference between your two diagonal measurements by 2, and move one corner of the frame to that measurement. It's done. The other corner will automatically be the same.
Willie T
Painting baseboard tips/tricks mahjohn Interior Decorating 15 10-29-2011 12:54 PM
Baseboard radiator question timothy918 HVAC 6 11-29-2008 05:00 AM
Tile baseboard with carpet? bpak04 Flooring 2 11-03-2008 01:28 PM
Replaceing Baseboard to curvy wall problem agfrag Carpentry 13 08-29-2008 04:40 PM
Need help with finding very wide baseboard Showbiz Carpentry 2 05-28-2007 08:52 AM
