Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 02-10-2009, 04:57 PM   #1
Baseboard Joints /Butt or mitre
I am installing MDF baseboards in my family room and debating how to best do a single joint in a 20' wall. Anyone have any thoughts and past experience or Pro tips on keeping the joint invisible?
Will a change in humidity winter to summer cause any issues with MDF
Chemist1961 is offline   Reply With Quote
Old 02-10-2009, 05:18 PM   #2
Carpenter
DecksEtc's Avatar
Mitre joint and dap.
Terry
DecksEtc is offline   Reply With Quote
Old 02-10-2009, 05:32 PM   #3
Do I bond the joint or just use dap to fill?
Old 02-10-2009, 06:30 PM   #4
Old School
Willie T's Avatar
Here's a link to another thread. Different installation, same idea.
Making a trim joint
Willie T
Old 02-10-2009, 07:02 PM   #5
Moderator
Termite's Avatar
You want what's called a scarf joint. It is essentially a miter that overlaps another miter. I'd highly recommend wood glue at the joint. With MDF, it is otherwise guaranteed to open up!
Old 02-10-2009, 07:42 PM   #6
Carpenter
DecksEtc's Avatar
Yes to the glue.
Also, it helps to shoot a nail through both pieces when they are in place.
Terry
Old 02-10-2009, 11:00 PM   #7
A good way to try and keep it from pulling apart is to splice it at a stud, so that you can nail both pieces together into a stud.
sausagefingers is offline   Reply With Quote
Old 02-11-2009, 07:45 AM   #8
Remodeling Contractor
use a scarf joint where joints need to be strong and secure, the miter angle is usually very acute: 30 degrees or less. This creates a big overlap between the parts, thus giving the joint lots of mechanical strength, as well a lot of gluing surface area.
Old 02-11-2009, 07:39 PM   #9
Thanks guys. What about humidity changes. I have never had any mdf in the house....
Old 02-11-2009, 08:02 PM   #10
Old School
Willie T's Avatar
Normal humidity doesn't effect it too much, but direct wetting will. The junk swells when it gets wet.
Willie T
Old 02-11-2009, 09:50 PM   #11
Dont use the spackle type dap on miter or butt joints on any wood transition. These joints will expand and contract with humidity. Always use caulk for these joints, interior you can use 20 yr. exterior always use 50 yr. Murph
Murphy is offline   Reply With Quote
Old 02-11-2009, 10:44 PM   #12
Moderator
Termite's Avatar
I love working with MDF, but have regretted installing MDF casing, base, and crown in a number of rooms in my home. It is absolutely affected by humidity in the home (or lack of humidity). Moreso than wood trim in my opinion. I have no gaps in the joints of my pine and oak mouldings, but the MDF looks like hell 5 months out of the year.
Old 02-12-2009, 06:11 AM   #13
Did you glue these joints? Of is it even a good idea to glue the joints?
Old 02-13-2009, 10:45 PM   #14
I use a 22.5 scarf joint with LOTS of glue, MDF likes glue. I also put a backer behind the joint and nail to that...all my scarf joints look like the day i did them, the copes opened up a little this winter, but not too much.
TBFghost is offline   Reply With Quote
Tags
baseboard, mdf
UGH! Trim joints are opening up! javan Carpentry 5 12-16-2008 07:05 AM
caulking butt joints on siding downunder Building & Construction 7 11-13-2008 04:56 AM
Tile baseboard with carpet? bpak04 Flooring 2 11-03-2008 01:28 PM
Replaceing Baseboard to curvy wall problem agfrag Carpentry 13 08-29-2008 04:40 PM
convert from gas boiler to electric baseboard marks5894 HVAC 1 10-21-2007 01:22 PM
