Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 02-28-2008, 04:21 PM   #1
Baseboard, How do you trim out a bullnose corner
All I can think of is to make or buy a corner block.
kcdave is offline   Reply With Quote
Old 02-28-2008, 06:00 PM   #2
Woodworker and Contractor
Kingfisher's Avatar
cut the ends at 22.5* and a filler ith 22.5* goes between the two baords as they meet at the corner to wrap aroung the rounded shape better
Kingfisher is offline   Reply With Quote
Old 02-28-2008, 06:21 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Apply Kingfisher's advice. Do some test cuts, and dry-run mock-ups, till you get the hang of it.
The corner will look similar to this:
- Build Well -
Old 02-28-2008, 11:04 PM   #4
ya, that will definately take a few test cuts, wish I was painting mine too
Thanks tho, I like that idea better.
Old 11-24-2008, 03:23 PM   #5
Thanks for all you input back then. It helped me with a clients house today. I never had to install baseboard around these corners before. A quick look up before i head out solved the issue. Cheers.
TimN8er is offline   Reply With Quote
baseboard trim gaps on stairs beppygirl General Discussion 8 02-24-2008 02:31 PM
Baseboard - inside corner Potomac101 Flooring 11 02-16-2008 11:44 AM
attaching baseboard trim DIY4EVER Carpentry 11 11-28-2007 01:31 PM
Installing baseboard trim helpless handyman Carpentry 4 10-05-2007 10:16 AM
Repair damaged bullnose corner DRCollier Building & Construction 2 07-15-2007 10:46 AM
