Baseboard Higher Than Toekick - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-06-2009, 02:04 AM   #1
Rewards Points: 462
Baseboard higher than toekick
Hello all,
Looking for suggestions on how to handle this situation.
The kitchen cabinets have a 3" toekick but the baseboard I have installed is 4.25". This is the only place in the house where the baseboard meets a toekick and although I don't care for the way this looks, I can't think of any other solutions.
Any ideas?
Richo is offline   Reply With Quote
Old 06-06-2009, 02:58 AM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
I would return the baseboard back into the wall with a 45 degree miter cut/ leaving it when finished flush with the outside corner and then paint the exposed bottom portion of the wall next to the toe kick with some flat black paint. BOB
Old 06-06-2009, 07:21 AM   #3
You could cut your baseboard as you would normally to go around a corner, return he lower portion to the toe kick and return the top 1 1/4" to the cabinet. Either notch the board or do it with 2 pieces.
CVGFir is offline   Reply With Quote
Old 06-06-2009, 11:13 AM   #4
Old School
cabinetman's Avatar
You got yourself a real problem there. Not much you can do to make it look planned. Toe kicks are usually 4" high, and 3" deep. From looking at the picture the base looks like it sits ahead of the stile, which is flush with the wall.
That type of offset is very difficult to work around. Personally, that offset would be a continuous source of irritation to me. I would cut the base to fit under the toe kick, and miter, and return it to the toe kick of the cabinet.
If it has to sit as it is, cut what's called a "self-edge", which is basically a very narrow return made by a miter leaving the waste piece the width of the base. attach the mitered piece to a mitered edge on the base, and the straight cut on the waste piece sits on the wall and finishes at the right edge of the stile.
cabinetman is offline   Reply With Quote
Old 06-06-2009, 02:03 PM   #5
Custom Cabinet Maker
Try making a Plinth block that wraps under the kick and is Higher than the base on the front portion, then just end your base against the block
skymaster is offline   Reply With Quote
Old 06-08-2009, 12:01 AM   #6
Rewards Points: 462
Thanks for all the great suggestions...much appreciated. Returning the edge of the baseboard really dressed it up and it looks so much better than it did before (especially with the new flooring)
As for the toekick, I built these cabinets 10 years ago and just copied the dimensions of the previous 1970s cabinets, which had a low toekick height. At the time the baseboard was 2 1/4" and it wasn't until years later when I replaced all the baseboard that I realized I had a problem here
Painting baseboard tips/tricks mahjohn Interior Decorating 15 10-29-2011 11:54 AM
Tile baseboard with carpet? bpak04 Flooring 2 11-03-2008 12:28 PM
Replaceing Baseboard to curvy wall problem agfrag Carpentry 13 08-29-2008 03:40 PM
Installing kitchen wall cabinets higher than spec recommendation? alexz General DIY Discussions 14 07-20-2008 11:32 PM
Need help with finding very wide baseboard Showbiz Carpentry 2 05-28-2007 07:52 AM
