Baseboard Help For A Newbie! - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-03-2011, 09:54 AM   #1
Question
Baseboard help for a Newbie!
Hi Everyone!
I need to replace a small section of baseboard molding - it looks like 1/4 or 1/2 round? It's at the bottom of a section of paneling. It is a ver long oiece and I only want to cut out the bad section of it and replace it. Can I do that without taking the whole piece off the bottom of the wall? Or is there a way to just cut that one section out.
Thanks!
Pam
pamelak855 is offline   Reply With Quote
Old 02-03-2011, 10:10 AM   #2
DIY staff
Rewards Points: 7,174
There is a handy cutting tool that will do that--It's called a multi- tool.
Mine came from Harbor Freight--cost for a cheap one $29--
It just might be cheaper and neater to replace the entire length of trim--
pamelak855 (02-03-2011)
Old 02-03-2011, 10:27 AM   #3
Retired
Edgar214's Avatar
Mike you are right on. Don't know how I survived with out my "multi-tool".
Mike
Edgar214 is offline   Reply With Quote
Old 02-03-2011, 11:24 AM   #4
DIY staff
That muli-tool was a happy surprise----I bought it as a one time use tool --odd job of replacing outside window sills---
That silly little tool comes off the truck almost every day---Glad I got the Harbor Freight one---the blades are half the price of the other brands--
So rare to find a tool that is actually better than expected---Mike---
Willie T (02-03-2011)
Old 02-03-2011, 11:51 AM   #5
Rewards Points: 56
Another way to handle this might be to split through the bad section of shoe moulding with a chisel, pull it away from the wall, lay a piece of scrap laminate, 1/4" plywood, or whatever you have, under it, and cut it with a back or hand saw, just like you would otherwise, except that you have to be careful to not damage the floor. The only thing is that you will probably slit it where you don't want to if you try to pull it and the nails out together, so the trick is to drive the nails through the moulding with a nail set, and then putty the holes when you are done. If you can't see the nail heads, just pry it away from the wall enough for the nails to just slightly crack the surface, then drive them through.
Old 02-03-2011, 12:33 PM   #6
Rewards Points: 5,336
If the molding comes off easily, I'd take it off and cut the piece off at a 45 degree angle and put the new piece on. Scarf joints don't open as much as butt cuts.
Ron
Newbie question - thermostat functioning and baseboard heaters keith-k HVAC 2 10-26-2010 10:20 AM
Problem with 240V Elect Baseboard Heater JRHP Electrical 4 10-04-2010 10:30 AM
Laminate flooring / baseboard gap question willy0314 Flooring 0 08-07-2010 10:48 PM
Partial hydronic baseboard to radient floor conversion Jeepsail HVAC 4 01-17-2010 05:47 PM
Baseboard dilema Allyson Flooring 5 09-04-2009 09:30 AM
