Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 07-07-2007, 04:17 PM   #1
Closed June 29, 2007
Baseboard corners help
I just moved into a home that has gaps at the corners where the baseboard moldings should meet. Can I just caulk the gap? Any certain caulk I should use?
jcurts75 is offline   Reply With Quote
Old 07-07-2007, 05:00 PM   #2
Eibwen
You can use whats called "painters caulk" to fill in any minor gaps at joints or between the baseboard and the wall. Its just smooth caulk with no silicone and can be touched up with paint if needed.
Sammy is offline   Reply With Quote
Old 07-07-2007, 05:39 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Is the baseboard painted? If it is painted, by any chance is it white?
For painted baseboard use a White LATEX caulk.
If it's stained wood baseboard, use a stainable wood putty or one that is pre-colored that will match the stain.
- Build Well -
Old 07-08-2007, 07:49 AM   #4
Thanks for the advice! I bought all purpose caulk, but didn't think this would work as well. And it is white baseboards.
Curved corners where drywall meets? SouthGAreno Remodeling 12 01-17-2013 04:10 PM
Outside corners to two different baseboard rooms cygnusx1 Flooring 6 03-04-2009 06:58 PM
Tile Baseboard leted_82 Flooring 3 07-07-2007 12:57 PM
Need help with finding very wide baseboard Showbiz Carpentry 2 05-28-2007 08:52 AM
Baseboard Question in New Home BusterPercheron Building & Construction 5 11-20-2006 07:16 AM
