Baseboard - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-30-2010, 10:19 PM   #1
Question
baseboard
how to trim out bullnoise corners
mrmopar is offline   Reply With Quote
Old 10-30-2010, 11:08 PM   #2
jlhaslip's Avatar
Rewards Points: 1,564
You mean rounded drywall corners?
Cut some pieces with 22 1/2 degree angles and pre-glue them into corners that you can mount onto the wall.
I've had luck using a dowel the same radius as the corner and elastic bands as clamps.
Wax paper on the dowel first so they don't stick.
Make 4 corners at a time.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 10-31-2010, 12:01 AM   #3
Kinda like this...
sausagefingers is offline   Reply With Quote
Old 10-31-2010, 06:35 AM   #4
Handyman
Rewards Points: 512
I usually use a cork type trim. It is very flexible. Its very hard to find though...you have to call around to lumber stores. The box stores, at least in my area, do not stock it.
canadaclub is offline   Reply With Quote
Old 11-03-2010, 12:26 PM   #5
Would the same 22 1/2 degree cut also apply to installing crown molding around a bullnose corner?
RobertN is offline   Reply With Quote
Old 11-03-2010, 12:28 PM   #6
Jay123's Avatar
Jay123 is offline   Reply With Quote
Old 11-03-2010, 11:33 PM   #7
Wood Flooring & Carpentry
lawndart's Avatar
Originally Posted by Jay123 View Post
Hello JF
To the original poster. If you use this method make sure you caulk the top of the baseboard to eliminate the shadow line.
lawndart is offline   Reply With Quote
Old 11-04-2010, 09:51 AM   #8
Jay123's Avatar
Hey LD.
Problem with 240V Elect Baseboard Heater JRHP Electrical 4 10-04-2010 09:30 AM
Laminate flooring / baseboard gap question willy0314 Flooring 0 08-07-2010 09:48 PM
Installing some baseboard across 2 different floor types? BigJohnny Building & Construction 9 08-03-2010 11:41 AM
Partial hydronic baseboard to radient floor conversion Jeepsail HVAC 4 01-17-2010 04:47 PM
Baseboard dilema Allyson Flooring 5 09-04-2009 08:30 AM
