Baseboard - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-13-2008, 09:17 PM   #1
Rewards Points: 150
baseboard
when putting in baseboard what is the best way to take the measurments?
drewhart is offline   Reply With Quote
Old 11-13-2008, 09:19 PM   #2
All trades carpenter
Gotta narrow it down a bit and we could help you!
CrpntrFrk is offline   Reply With Quote
Old 11-13-2008, 09:24 PM   #3
Electrician
I like to use a tape measure, seems to be the easiest.
chris75 is offline   Reply With Quote
Old 11-13-2008, 09:28 PM   #4
Old 11-13-2008, 09:31 PM   #5
Electrician
Originally Posted by CrpntrFrk View Post
Like no one knew that was coming...
Old 11-13-2008, 11:27 PM   #6
when you measure ad an 1/8 of an inch so it will be tight. are you going to cope or miter the corner?coping makes a better job if your corners aren't square,if you don't know how to cope it's not that had to do but kind of hard to explain.You may find something on you tube do a web search on cope a joint or using a coping saw and you may find something,and if you cut a little long if it's to long it can be adjusted regards Rob
super carpenter Rob is offline   Reply With Quote
Old 11-14-2008, 12:16 AM   #7
Registered User
Termite's Avatar
With trim, measure once, cut three times. I always cut a little long and then "sneak up" on it by test fitting and cutting a little at a time. That ensures the tightest fit.
Old 11-14-2008, 08:56 AM   #8
Rewards Points: 150
i was original going to measure by counting how many beer cans i could line up, but i like the tape measure idea better. but now i am wondering if is better to cut one side of a corner to be mitered, then putting it on the wall and meauring from the outside of that piece to the other wall? ive never installed base before and i'm just wondering if there is some generaly accepted procedure.
Old 11-14-2008, 10:13 AM   #9
Yup, that's how you get the best fit for sure and how I have been doing it for decades.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 11-14-2008, 10:17 AM   #10
You will find that mitered cuts on baseboards is a real talent since most walls are not that square after the drywall, taping and texturing has been applied.
Make sure you have lots of wood filler on hand especially for older homes.
Old 11-15-2008, 08:15 AM   #11
It's a matter of taste but being miter challanged, I like to use the corner blocks, and Marvin, I find it best to get my wood filler in the 5 gal.bucket
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 11-15-2008, 09:07 AM   #12
Oh yea, that's me all over.
I like to blame the bad framing on the framers and the bad sheet rock on the drywall guys. But some times I am all of those...
Mostly I do remodels and have to do a lot of correction work to get things lined up in homes that were build a very long time ago and have settled. This makes for some interesting corners and doing a nice miter job is not possible for what the homeowner wants to pay.
Old 11-15-2008, 09:39 AM   #13
Corner blocks do have thier place but I feel that in most cases a coped corner brings the best results!
Old 11-16-2008, 06:53 PM   #14
you're probably wondering how to measure from an inside corner to an inside corner, where a tape measure can't really reach?
use "pinch sticks" for this - any straight small ripping or scrap. overlap the sticks so both ends hit the wall, then either measure what you have while still holding on, or just transfer that length to your board.
also, where possible, mark the board IN PLACE. this is a good cardinal rule of trim carpentry. for example, you have a run from an inside corner to an outside corner: do your cope or butt joint on one end, then lay it in place, and take a sharp pencil and scribe the back of it where it meets the wall. dead nuts.
for cuts mid wall, make sure you do scarf joints. simply miter 30 degrees on the end of the board in the middle of the run. then hold up another board with a 30 cut, or the with the other cut (whichever is accessible), and mark that bastard in place.
you should be able to do all of it by marking in place. that will get you the fastest, highest quality results.
wombosi is offline   Reply With Quote
Tile baseboard with carpet? bpak04 Flooring 2 11-03-2008 01:28 PM
Replaceing Baseboard to curvy wall problem agfrag Carpentry 13 08-29-2008 04:40 PM
convert from gas boiler to electric baseboard marks5894 HVAC 1 10-21-2007 01:22 PM
Need help with finding very wide baseboard Showbiz Carpentry 2 05-28-2007 08:52 AM
Baseboard Question in New Home BusterPercheron Building & Construction 5 11-20-2006 07:16 AM
