Base Trim Around Stairs/landings...? - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-19-2010, 09:02 AM   #1
base trim around stairs/landings...?
I have a landing at the top of my stairs, and then another step to the left to get onto the second level of the house. I can't come up with a base trim style that doesn't look goofy to me. Is there a preferred way to do this?
base trim around stairs/landings...?-trim_1.jpg
or
base trim around stairs/landings...?-trim_2.jpg
I'm kind of leaning towards #2, but then the trim might look funny at the bottom of the stairs...any pointers?
Thanks!
red86yota is offline   Reply With Quote
Old 02-19-2010, 09:32 AM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
with #2; the angled piece at the left (going from the main floor to the landing). what would the base set against on the bottom of the base? It would look really odd (in my opinion) to just have it floating across that little bit of wall.
what do you thing of going full vertical at that point.
also, what are you using? an actual wood base mould or something such as vinyl cove base moulding.? That would make a huge difference how things could be dealt with and resultingly how they would look with a open end.
Old 02-19-2010, 09:51 AM   #3
firehawkmph's Avatar
Rewards Points: 1,864
Red,
you could do option one if you return the base at the open ends. In other words miter it back into the wall. This is assuming the area where the one piece of base runs into the riser on the left side had a clean edge where the drywall runs into it. I don't care for the second option, the angle has no place there.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 02-19-2010, 09:55 AM   #4
5/4 by 6 with base cap on top. use #2 with vertical like nap say then at stinger stop 5/4 but continue with base cap
The older I get the better I was
Old 02-19-2010, 12:35 PM   #5
thanks for the feedback.
i have pine 4.5" (?) tall base trim - painted white.
for option two, I was thinking about putting in a fake stringer to look like the stained pine stringer you can see on the right. it does look kind of strange, but I thought it would look best to have a continuous run of trim.
i like the idea of 'returning' the trim at the two spot in option one. i would basically return the two butt cuts, right? i hadn't thought of the return, but that will make the end look nice and finished.
we will have carpet on the second floor, wrapping down the stairs like it is now. so the riser on the last step would be covered in carpet...if that makes any difference.
Old 02-19-2010, 12:46 PM   #6
That's correct. It should look fine with the carpeting.
Mike Hawkins
Old 02-21-2010, 09:21 PM   #7
remodeling pro
I always turn the piece at the top of the landing (shown running on an angle in option 2) as a vertical piece. This allows the base to transition the elevation change as a continious trim and looks much better than returning it on itself in the middle of the wall. Since the existing stringer down the wall is so thick, I agree that I would use 5/4 with a base cap instead of thinner factory base. This will be much more attractive, as you can use a fatter profile base cap profile to reduce visibility of the overly thick exposed stringer. Only the base cap should run up the stringer, not the entire height of the base and cap. This will require a little triangle filler at the top where the existing stringer flattens out. Glue it in place, spackle, sand and paint.
troubleseeker is offline   Reply With Quote
Old 03-12-2010, 05:43 PM   #8
see if u can come up with something like this
base trim around stairs/landings...?-bobby-escaleras-200.jpg   base trim around stairs/landings...?-bobby-escaleras-201.jpg
01stairguy is offline   Reply With Quote
Old 03-12-2010, 05:44 PM   #9
one more
base trim around stairs/landings...?-bobby-escaleras-202.jpg
The Following User Says Thank You to 01stairguy For This Useful Post:
oh'mike (03-12-2010)
Old 03-13-2010, 05:17 PM   #10
remodeling pro
Nice, stairguy; ABSOLUTELY NOTHING transitions as nicely as an easement like you have here, but I think this is way beyond anything required in his situation, and probably not practical to assume that he the tools to profile the stock.
painting trim and base boards fabian Painting 19 10-10-2010 01:48 AM
Base Board Trim cambishop Carpentry 10 01-23-2010 08:43 AM
1000sq ft of teak, do i remove base trim, saw door casing ?? PendletonCowboy Flooring 4 10-20-2009 04:04 AM
Help with post base trim wombosi Carpentry 1 10-05-2008 09:54 AM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 03:19 PM
