Base With Shoe Moulding - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-24-2013, 04:16 PM   #1
msaeger's Avatar
Rewards Points: 260
Base with shoe moulding
I need to cover the 3/4" gap I left when installing hardwood flooring. I don't want painted baseboards I want natural wood or stained. I want to something nicer than just quarter round if I can.
Any suggestions for combinations of base + shoe moulding or some kind of built up moulding that will cover my 3/4" gap. Do people do built up mouldings that aren't painted? Looking on the web I see mostly painted.
msaeger is offline   Reply With Quote
Old 10-24-2013, 04:29 PM   #2
Rewards Points: 13,752
No idea why you would have left that much gap.
There is no right or wrong way of doing it, what looks good to you is the way to go.
I suggest going to a real lumber yard and looking over some of there moldings.
Base caps, cove moulding there's lots of moldings that would work.
http://www.bing.com/images/search?q=...iles&FORM=IGRE
Old 10-24-2013, 04:34 PM   #3
DIY staff
Rewards Points: 7,174
As Joe suggested--go to a millwork house or better lumber yard---
Good quality base molding is 5/8" thick or more---shoe is 1/2"--so that gap will be covered----
Old 10-24-2013, 08:20 PM   #4
msaeger's Avatar
Rewards Points: 260
I left that big of a gap because that's what the flooring manufacturer said to do. Probably overkill but I figured I would be using a shoe or something anyway.
Old 10-24-2013, 08:30 PM   #5
msaeger's Avatar
Rewards Points: 260
I have been looking on google but nothing jumps out at me so I am just wondering what other people think looks good.
Old 10-26-2013, 06:37 AM   #6
CitadelBlue's Avatar
Rewards Points: 97
you said you didn't like the white shoe molding, but this is what I have .....
I have the 3/4" gap but actually went under the 1x4 and the shoe molding just covers the small gap between the floor and 1x4
Ken
Because you NEVER have enough room .........
See my Trailer and Hitch Thread
CitadelBlue is offline   Reply With Quote
The Following User Says Thank You to CitadelBlue For This Useful Post:
msaeger (10-26-2013)
Old 10-26-2013, 08:24 AM   #7
Rewards Points: 2,638
Commonly, the bottom 3/4" of drywall is removed so that the hardwood floor can come up close to the wall.
SPS-1 is offline   Reply With Quote
Old 10-26-2013, 10:51 AM   #8
In a little over my head
Rewards Points: 706
We did white baseboards and unpainted oak shoe molding. Looks good, IMO.
ratherbefishing is offline   Reply With Quote
The Following User Says Thank You to ratherbefishing For This Useful Post:
Old 10-26-2013, 10:04 PM   #9
msaeger's Avatar
Rewards Points: 260
I thought about doing that but when I looked at it closer there were screws at the very bottom of the drywall that would have been in the 3/4" getting cut off so then I figured I would need to remove those and move them up higher. Which may not have been that big of a deal but I just decided to have the big gap.
Plus having the shoe molding will help hide anyplace the floor is uneven.
Old 10-27-2013, 07:51 AM   #10
Yeah, I just did a hardwood floor, and I had nails in the bottom of the drywall too. Put new screws a couple of inches up, and then pulled the screws and bottom drywall. Yes, it was a bit of a pain, but fortunately was only one room.
Old 10-27-2013, 10:12 PM   #11
msaeger's Avatar
Rewards Points: 260
I think I am liking "craftsman style" based on what I am seeing on google on the base anyway. Something simple like this only natural wood instead of white. http://farm7.staticflickr.com/6171/6...3ece80ef_z.jpg
I don't know if I want or could pull off doing the door and window casings in this style. How big of a sin is it to mix styles also I have a capcod so having craftsman style is probably a sin too Although something like this for casing would maybe be easier than mitered corners. http://hostedmedia.reimanpub.com/TFH..._CRATRM_11.jpg
Installing a Sterling shower receptor in a mortar base repoocaj Plumbing 2 11-19-2011 07:52 AM
Base Moulding vs. Bullnose Tile Surround sullijos Flooring 7 11-10-2011 10:24 AM
Is it ok to leave a tiny gap between the shoe moulding and the floor? esacasa Flooring 1 09-10-2010 06:22 AM
How to create a curved wooden base shoe? hayzen Carpentry 3 07-28-2009 03:29 PM
Base molding or carpet first??? Dan N Flooring 5 02-01-2007 08:29 AM
