Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 01-30-2011, 10:53 AM   #1
Base molding question
I am installing new carpet and floor tile. I am confused regarding whether the base molding is installed before or after the carpet and tile. My understanding is that tile should be installed before the molding. Here is the dilemna--at one point, the carpet meets the tile so the base molding must be mitered at that corner. if the tile is installed prior to the carpet, the molding will be uneven (higher where the tile is installed). I would really like some help with this problem.
aunteemom is offline   Reply With Quote
Old 01-30-2011, 10:56 AM   #2
Experienced
Jackofall1's Avatar
If you set the moulding 1/2" off the sub floor for carpet, is that not the same height as the moulding off the tile?
Old 01-30-2011, 01:35 PM   #3
Install the tile. Install the base over the tile. Make the carpeted area base the same height as the tile and, if necc adjust the height of it to about 1/2" above the floor sheathing
mrgins is offline   Reply With Quote
The Following User Says Thank You to mrgins For This Useful Post:
Willie T (01-30-2011)
Old 01-30-2011, 02:08 PM   #4
A door a day is all I ask
TheDoorGuy's Avatar
By doing what Jack and Mr Gins say, you will make a better looking carpet installation and
your carpet installer will be happy also!!
Richard The Door Guy
TheDoorGuy is offline   Reply With Quote
Base molding and flooring aunteemom Flooring 7 01-30-2011 09:03 PM
Sink base vs regular base cabinets... J187 Kitchen & Bath Remodeling 3 12-03-2010 08:40 AM
Base Moulding Question diykc General Discussion 8 01-13-2010 10:09 AM
Crown molding on with catherderal celing for LED lights My_attempt Carpentry 20 07-22-2009 11:52 AM
Base molding helpless handyman Carpentry 16 04-01-2008 06:06 PM
