Base Molding &carpet - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-02-2014, 09:08 PM   #16
Rewards Points: 878
Originally Posted by Fix'n it
how can the carpet go under the molding, when the molding is directly on the floor ?
Good question.
Mstrlucky74 is offline   Reply With Quote
Old 02-02-2014, 09:16 PM   #17
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 182
The carpet does not need and is not supposed to go under the molding. The molding is not needed to hold it down. It is tucked into the gap between the tack strip and the molding, the tack strip is designed to hold it there. The nails on the strip hold the stretch and the bevel on the strip allows you to tuck in the carpet.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 02-02-2014, 10:04 PM   #18
Rewards Points: 240
i understand that. but it isn't what he said.
i have always seen the carpet go under the base. if for nothing else = with the base directly on the floor, a thick pad and carpet up to it. the pad and carpet height would hide a good portion of the base.
Fix'n it is offline   Reply With Quote
Old 02-02-2014, 10:09 PM   #19
Rewards Points: 182
It would hide less than an inch of the base. The pad only goes up to the strip, so you only have the carpet thickness at the base.
Old 02-03-2014, 06:03 AM   #20
Rewards Points: 878
One other question...curious. Does the tack strip go right against the molding or leave some space between the two? Thanks
Old 02-03-2014, 07:11 AM   #21
firehawkmph's Avatar
Rewards Points: 1,922
Ms,
Leave the tackles strip install for the carpet installer. He'll put it where it needs to be. It doesn't go right up against the base.
Mike Hawkins
firehawkmph is offline   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
Mstrlucky74 (02-03-2014)
Old 02-03-2014, 07:11 AM   #22
Rewards Points: 182
A space between. About 3/8". If the carpet is thicker than average, a little more. Need room to tuck in the carpet.
The Following User Says Thank You to rusty baker For This Useful Post:
Old 02-03-2014, 07:13 AM   #23
Rewards Points: 182
Originally Posted by firehawkmph View Post
Ms,
Mike Hawkins
Yep. Many times the HO installs It backwards.
Old 02-03-2014, 07:52 PM   #24
Professional
TotalHomeworx's Avatar
I have always lifted it up a bit (3/8" to 1/2") but asking the installer would be best.
I have no problem with MDF trim. Looks a lot better then finger jointed pine, it's a consistent size, cheap, less trees to cut down. Just keep it away from moist areas, get a few good coats of paint on it and it will last a long time. Old school guys are afraid of change.
TotalHomeworx is offline   Reply With Quote
Old 02-03-2014, 09:08 PM   #25
Ole Wood Worker
BigJim's Avatar
Rewards Points: 798
Yep, if it ain't broke don't fix it. LOL
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Best way to paint stained base and door molding h22lude Painting 7 05-29-2013 09:16 AM
molding over molding, Can it be done? jerry1977 Remodeling 3 07-27-2011 01:31 PM
Base molding and flooring aunteemom Flooring 7 01-30-2011 08:03 PM
How to create a curved wooden base shoe? hayzen Carpentry 3 07-28-2009 03:29 PM
Base molding or carpet first??? Dan N Flooring 5 02-01-2007 08:29 AM
