Base Molding Angle Cut - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-02-2014, 12:30 PM   #1
Rewards Points: 874
I'm going to be installing this base molding and I have two questions What type saw would I use to cut the corner angle? Could I use a miter? I have to buy one anyway for my crown. How do I get the measurement for the corner angle so I cut it right? It's a 90 degree corner. What type nails should I use. I have a porter cable compressor and nail gun and it came with 16 gauge 2" nails. Thanks a lot
Mstrlucky74 is offline   Reply With Quote
Old 02-02-2014, 02:12 PM   #2
Rewards Points: 13,266
#1, I would not be using MDF trim, but ha it's your house.
Since your also going to be cutting crown I'd buy a 12" compound miter saw.
Best way to fit base is to always cope the joints.
Coping will give you a tighter fit and less likely for gaps to open up.
If you make the cuts at a 46 deg. angle only the exposed tips of the trim will be touching and they will fit tighter.
I use a Starrett 505-7 for figuring odd angles.
http://www.zorotools.com/g/00061622/...m_campaign=PLA
Old 02-02-2014, 02:29 PM   #3
Like joecaption said, cope inside corners. You can buy a copeing saw but I found it a little tricky so I just use my scrowl saw and it does the same thing. YouTube how to cope base molding that's how I learned how to do it and it looks great once you get the hang of it.
handyman_squire is offline   Reply With Quote
Old 02-02-2014, 02:30 PM   #4
Rewards Points: 874
Well I bought a hand miter...only $8 and I only have about 14 cuts. Hope it works ok
Old 02-02-2014, 02:37 PM   #5
I'll bet after the first few cuts you'll want to throw that thing in the trash.
To sloppy, the blade will flop around, no way to adjust the angle, with a cheap one like that there's not enough set on the blade so it's going to drag instead of cutting.
Old 02-02-2014, 04:05 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
for mdf base mitre cuts for inside corners are perfectly fine. mdf is a engineered product and much more stable than real wood it doesnt expand and shrink with humidity.
woodworkbykirk is online now   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
Tom Struble (02-03-2014)
Old 02-03-2014, 09:00 PM   #7
Professional
TotalHomeworx's Avatar
If you have to ask how to cut a miter I would avoid trying a cope. Watch some youtube videos. Be careful of plumbing and pocket doors with your 2" nails, try to hit studs. Get good with a caulking gun
TotalHomeworx is offline   Reply With Quote
Old 02-03-2014, 09:33 PM   #8
Jb1234's Avatar
Rewards Points: 87
Yeah, power chop saws are cheap enough, buy one. If you plan on doing any form of remodeling/upgrading this will be one of your most valuable tools. Handsaw miter boxes are garbage. The one thing I hate on the internet are DIY blogs from people that have no business giving advice. On "Hipster Chick does Crown Molding" blogspot, here I cut all my crown with a handsaw and look at how great it is. I only used 7 tubes of caulk and I painted it with thickened cows milk, aren't I amazing. Before you cut, nail or paint, read the multitude of credible articles and watch the professionals on YouTube. Now to the OP, what I wrote above was to be funny, but with you not knowing the extreme fundamentals of carpentry, I assume you are doing this on a whim and got a bit ahead of yourself.
Jb1234 is offline   Reply With Quote
Base molding in this closet? Tricky. Dave88LX Carpentry 25 02-22-2013 10:21 AM
Sink base vs regular base cabinets... J187 Kitchen & Bath Remodeling 3 12-03-2010 08:40 AM
Can't find instr. on cutting 135 degree inside angle in crown molding Hossenfeffer Carpentry 8 05-27-2010 08:25 PM
base molding painting w/ carpet fabian Painting 2 04-02-2009 08:57 PM
Base molding or carpet first??? Dan N Flooring 5 02-01-2007 09:29 AM
