Barn Board Planks - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-27-2013, 10:48 PM   #1
Rewards Points: 87
Barn board planks
What type of fastener should I use to attach my finished 1"x12" pine barn board to my studs?
For reference im basically replicating this wall paneling:
hellonoko is offline   Reply With Quote
Old 08-28-2013, 06:12 AM   #2
kwikfishron's Avatar
Rewards Points: 586
I'd use a 7d ring shank siding nail. I hope you're planning on sheetrock between the studs and them boards.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
hellonoko (08-28-2013)
Old 08-28-2013, 07:08 AM   #3
Rewards Points: 13,712
kwick is right (of course ) Without the sheetrock first you may as well leave the window open.
I'd change the outlet boxes to the adjustable style so they can still be flush with the finished wall.
https://www.platt.com/platt-electric...px?zpid=423518
Old 08-28-2013, 10:24 AM   #4
Rewards Points: 87
Thanks, yes I put up sheetrock with a dark paint.
And behind that 3.5 inches of Foamular with the gaps sprayed and taped in the stud wall and behind the stud wall another 2 inches of Foamular with no thermal break also taped and sprayed at the joints.
Didn't know about those kind of boxes but the electricians said they wouldn't mind using longer screws. Good to know about them though. Thanks!
Old 08-28-2013, 05:02 PM   #5
If there going to use longer screws there also going to have to use box extenders.
Whole lot easy to just use the right box.
Old 08-28-2013, 06:37 PM   #6
Rewards Points: 87
Even though the drywall is all up and finished?
Old 08-28-2013, 07:32 PM   #7
If the rocks already up then use box extenders.
http://www.texastoolbox.com/tile-backsplash.html
Old 08-29-2013, 08:03 AM   #8
AHH, SPANS!!!
Rewards Points: 1,166
trim screws would be another option for putting the 1x material on the wall...
hand drive is offline   Reply With Quote
The Following User Says Thank You to hand drive For This Useful Post:
hellonoko (08-29-2013)
Old 08-29-2013, 12:06 PM   #9
Rewards Points: 87
@hand drive - thanks, I will keep that in mind.
Replacing Rim Board behind old Deck Ledger osubuckeye88 Building & Construction 11 10-26-2012 07:34 PM
Dark barn board on wall Rosalind Painting 3 01-13-2012 02:12 PM
shower rebuild - need help with backer board & green board johndoe12345 Tiling, ceramics, marble 2 11-27-2011 01:16 PM
wooden board under sliding door Wiscbldr Building & Construction 1 07-08-2011 07:19 AM
Finishing barn board for interior use colcream Carpentry 6 06-20-2011 03:02 PM
