Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 07-10-2009, 01:05 PM   #1
Default Bar top
Does anyone have any inexpensive ideas for creating a 12 foot bar top. It's for a cafe. I was thinking of using plywood and putting stainable wood skin with cove molding around the edges. But I trying to think out the feasibility.
Thanks for any advice.:confused1 :
CORNUCOPIA is offline   Reply With Quote
Old 07-11-2009, 09:48 AM   #2
In a commercial atmosphere, you might want to rethink the side veneer. It won't stand up to the daily abuse it will get. Use solid wood to cap the edges. You want to use a good glue and mechanical fasteners to keep the wood attached to the top.
Plywood doesn't have the dent resistance of solid wood, so if you expect to do brisk business you might want to try a solid wood top or a wood look laminate.
Ron
Old 07-11-2009, 10:19 AM   #3
Ron
Thank you Ron. The base is a 12' solid wood wine rack. I think I'm going to investigate your suggestion. Sounds Good. Thank you.
Old 07-29-2009, 02:41 PM   #4
Master Joatmon
Default My bartop plans...
I plan on using 3/4 OSB topped with bamboo flooring. If it's strong enough to walk on, it should be fine for a bar top. I will trim it out in oak and then a number of coats of an oil-based polyurethane meant for hard wood floors to protect it all from spills.
Chucky Jesus is offline   Reply With Quote
Old 07-29-2009, 04:25 PM   #5
Building codes guy, Mod
thekctermite's Avatar
Although there's some science to it, concrete makes awesome bar tops. You've got to use special concrete (not regular sackrete) and sealer, plus spend the money on melamine for forms. It won't save you any money but you'll only have to do it once. Done right they can make a heck of an attractive feature.
The building code is a minimum standard, and merely meeting it instead of exceeding it equates to building your project to the worst standard that the law will allow.
thekctermite is offline   Reply With Quote
Old 07-29-2009, 05:10 PM   #6
Default Thank you
Thank you all very much for the input. They all sound like great ideas. I have to see whats going to pass the Health Dept. lol
Stay Well
More On This Topic
Now let's take a look at a standard acoustic dreadnought guitar that is a good instrument, but does not feature all solid woods throughout the body. This particular guitar features high quality tuning machines, quality saddle, and a solid spruce top... Read More »
Hi, this is Jon on behalf of ExpertVillage. In this video clip, I'll be showing you the proper materials to sand with a belt sander. Some of the proper materials include an oak board or a chuck of pine. Now, these are actual wood. They're not veneers... Read More »
Today we are going to talk about patching veneer. Veneer is very thin wood that?s laid over another kind of wood. To give the appearance of solid wood. In this case we are looking at walnut. You can get veneer by buying a hole sheet of it. Just to make a... Read More »
Dreadnought Guitar Tips
Dreadnought Guitar Tips by Expert Village
Let's take a look at a standard size, dreadnought body, acoustic guitar that has electronics in it. This instrument features a solid spruce top; all better acoustic guitars will have a solid wood top, as opposed to a laminate or plywood construction. The... Read More »
Hi this is Jon on behalf of Expert Village, in this video clip I will be talking about estimating materials. As we take a look at our desk that we drew up I'm going to make the top out of a big sheet of plywood, in addition I'm going to have legs right... Read More »
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
