Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 09-18-2011, 09:02 PM   #1
Bar / counter design help
Hey guys need help trying to decorate cinder block for bar. Would like to make wooden base. Any plans how I cam do this out there?
Bar / counter design help-image-877100771.jpg
Aloha1 is offline   Reply With Quote
Old 09-18-2011, 09:34 PM   #2
Just incorporate the bar design around the cinderblock.
Why is that wall there?
Why can't you remove it?
Ron
B. Franklin 1759
Old 09-18-2011, 09:44 PM   #3
It's somewhat of a support wall. I was jus trying to figure how to build wood base around it. Would u secure plywood to it and go from there? How u secure plywood?
Old 09-18-2011, 10:00 PM   #4
One way is to frame the whole thing with 2x4's and secure your face plywood to the frame rather than the block. The frame will add dimension to it, but would be really secure place to attach sheet rock, or plywood.
Just use treated wood as the footer for the frame as it appears to be in a basement?
oldhouseguy is offline   Reply With Quote
Old 09-19-2011, 02:03 AM   #5
Old Hand
If the Cinder Block does not get moist you can just glue the plywood or "finished wood" directly to the Cinder Block and use some corner molding to finish it off. Saves money and time.
iliketowork is offline   Reply With Quote
Old 09-19-2011, 03:57 AM   #6
Thanks guys sounds like a plan. Really appreciate the insight!
Old 09-19-2011, 03:58 AM   #7
Appreciate all the advice
Old 09-19-2011, 06:35 AM   #8
You can not predict that it will never get moist. I agree you could do it that way, but the first time it gets wet... the glue will probably begin to fail.
Cutting Counter Top sleepysmurf Carpentry 3 08-14-2010 12:16 AM
General HVAC Design Issue Robert Green HVAC 4 05-29-2010 12:02 PM
Pop-up Kitchen Counter Receptacle paredown Electrical 11 03-12-2010 12:58 PM
attaching countertop analogmusicman General Discussion 22 08-10-2008 12:53 PM
