-   -   Bar / counter design help (http://www.diychatroom.com/f14/bar-counter-design-help-117636/)
Aloha1 09-18-2011 08:02 PM
1 Attachment(s)
Hey guys need help trying to decorate cinder block for bar. Would like to make wooden base. Any plans how I cam do this out there?
Ron6519 09-18-2011 08:34 PM
Just incorporate the bar design around the cinderblock.
Why is that wall there?
Why can't you remove it?
Aloha1 09-18-2011 08:44 PM
It's somewhat of a support wall. I was jus trying to figure how to build wood base around it. Would u secure plywood to it and go from there? How u secure plywood?
oldhouseguy 09-18-2011 09:00 PM
One way is to frame the whole thing with 2x4's and secure your face plywood to the frame rather than the block. The frame will add dimension to it, but would be really secure place to attach sheet rock, or plywood.
Just use treated wood as the footer for the frame as it appears to be in a basement?
iliketowork 09-19-2011 01:03 AM
No Need For Frame
If the Cinder Block does not get moist you can just glue the plywood or "finished wood" directly to the Cinder Block and use some corner molding to finish it off. Saves money and time.
Aloha1 09-19-2011 02:57 AM
Thanks guys sounds like a plan. Really appreciate the insight!
Aloha1 09-19-2011 02:58 AM
Appreciate all the advice
oldhouseguy 09-19-2011 05:35 AM
You can not predict that it will never get moist. I agree you could do it that way, but the first time it gets wet... the glue will probably begin to fail.
