Bamboo Fencing On Deck Help - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-11-2013, 01:55 PM   #1
Bamboo fencing on deck help
I purchased bamboo fencing (1" thick 36"x 8') to put around the inside of my deck railing. I would like to remove it in the Fall and put it back out in the Spring. I thought about wire hangers but can figure out how to go about doing it. Would anyone be able to come up with a solution?
RayH is offline   Reply With Quote
Old 05-11-2013, 02:54 PM   #2
Rewards Points: 13,732
Without some pictures it's hard to say how to install it.
Old 05-11-2013, 03:04 PM   #3
pics
OK, it is pouring here, so I am attaching two photos. One is the deck where I would like to hang the bamboo and the other is the roll of bamboo.
I would like to temporarily install it for Summer, possibly hanging it.
http://deckfotos.blogspot.com
Old 05-11-2013, 03:56 PM   #4
GBrackins's Avatar
Rewards Points: 2,108
Welcome to the Forum!
you could mount the bamboo sections to furring strips (near top and bottom) when are then attached to the deck guards/railing with screws .... remove the screws and store the panels for the winter.
you may want to edit your profile to include your location. many times answers to questions you may have are location based.
Good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 05-12-2013, 05:20 AM   #5
Too Short? Cut it Again!
I think long wire ties around the post or the spindles and over the metal rods running through the bamboo should hold without fir strips if top and bottom. I am seeing a metal rod through the bamboo pieces right? Cut them loose when the season is over? Get them in clear or a color to match bamboo?
Deck Staining Nightmare steven994 Painting 6 04-06-2014 09:10 PM
Surface Mounted Deck Post Problem sore thumb Building & Construction 17 04-06-2013 05:45 PM
Pergola over existing deck cpfullback Building & Construction 0 08-04-2011 11:36 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
