Baluster Installation - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-17-2013, 04:10 PM   #1
Baluster installation
Hello all,
I'm having one hell of a hard time trying to figure out what to do with my baluster spacing. Now the place i'm getting stuck is, how do i lay out the railing ?
I have 6 straight stairs and 6 curved stairs. The run of the rectangular stairs is 8 1/2" without the nosing.
So by code where i live, the maxiumum distance between posts is 4". So i decided to go with 3 posts per straight/rectagular stair, and 2 for the curved. Will this look weird? the spacing will not be the same between the curved stairs balusters and the rec stair balusters, only the first bal, which i'm thinking of having a 1 3/8 spacing for every stair for the initial bal.
i thought about using 1 3/8 from the riser for the first baluster and 1 3/8 from the edge of the nosing and put the middle spindle in the middle. Unfortuantely all the stairs are not exactly the same. Some are 8 1/2" some are 8 1/4". Do i adjust the middle baluster to fit?
I'm using 1/2 iron balusters. I did not start the spacing at the newel posts since i have a curved railing. I'm actually starting on the 6th rectangluar step.
Any help is appreciated.
the first pic in my photobucket is my stairs.
cybernation is offline   Reply With Quote
Old 03-18-2013, 08:52 AM   #2
GBrackins's Avatar
Rewards Points: 2,108
iron balusters? I thought I saw wood ones in the photo
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 03-18-2013, 08:56 AM   #3
1/2" round iron
Previous balusters were 1.5" wood
Old 03-18-2013, 08:59 AM   #4
You see the wood ones because I'm using it to prop up the railing
Old 03-18-2013, 09:25 AM   #5
GBrackins's Avatar
take a look at this sketch and let me know what you think ......
Gary
Old 03-18-2013, 04:01 PM   #6
Wink
The actual tread is 9 3/4 with nosing . In the diagram it's 8 1/2. Do I ignore the nosing for the calculation?
Thanks man!
Old 03-18-2013, 04:11 PM   #7
GBrackins's Avatar
you had given 8-1/2" as the tread depth with no measurement for the nosing. I calculated the spacing based upon the 8-1/2". You'll notice there is equal spacing of the balusters.
Gary
Old 03-18-2013, 04:24 PM   #8
Yeah I see, that I guess I was getting confused with some manual I was reading about spacing.
8 1/2 is usable space on the stair for the balusters, But the tread is actually 9 3/4. There's a 1 1/4 nosing.
I'm getting confused about the nosing part.
I suppose with 9 3/4 I have to use 3 balusters per stair until I hit the curved ones?
Old 03-18-2013, 04:41 PM   #9
GBrackins's Avatar
the spacing shown in the sketch provides for 3-3/4" between all balusters, why would you need 3?
Gary
Old 03-18-2013, 08:15 PM   #10
I found out why I'm so messed up.. My risers are not all the same thickness. Oops
Thanks for the diagram, ill just measure from the original riser.
Veneer Brick Installation jefsboys Remodeling 3 11-01-2012 07:42 PM
Sewage grinder pit and pump installation leff1rj Plumbing 15 02-04-2011 12:36 PM
casement windows installation versus double hung installation user82106 Building & Construction 2 06-16-2010 06:56 PM
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 01:19 AM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 08:46 AM
