Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-13-2008, 04:17 PM   #1
Default Ball Catch Striker Plate
Just installed pre-hung 48" interior french doors with pre-installed ball catches on top of both doors. Included are 2 striker plates. My question is, do the plates just get screwed to the top (underside of the header), or do they have to be indented inside of the wood itself. My friend seems to think he needs wood chisels and chip out the header wood for the striker plate to be indented inside of it so it's flush.
Thanks for any help
bklyn1028 is offline   Reply With Quote
Old 10-13-2008, 05:45 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
They need to be installed and "indented" into the wood, at the top of the door frame, in order to be flush.
- Build Well -
More On This Topic
If an engine could be considered a thing that needs to breathe, then the exhaust system can be instrumental in allowing the engine to breathe out more easily, giving it more power. Beefing up one's exhaust system is a very effective way to improve your... Read More »
Doors can be tricky simply because they have to look really good. Whether inside or outside, doors are one of the most visible areas of the house. They're usually well lit so every little drip and brush mark will show up. Use really good brushes for door... Read More »
Whether you are buying an exterior door for a new construction or you want to replace an older door, it is important to remember that the exterior doors of your home are the first impressions that are made upon your guest. Buying an exterior door is... Read More »
Hi! This is Daniel on behalf of Expert Village. In this clip, we are going to be marking for our strike. Now they do make templates which you can put over them and actually tap them with a hammer and it creates the outline for you; but since most people... Read More »
Hi I'm David Belch with Thermo Guard and today on behalf of Expert Village I am here to show you how to install windows. What I want to show you now is how to measure a wood sash window. The wooden windows come with a wooden jamb frame header and sloping... Read More »
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 09:38 PM
Catch Basin sebas54 General Discussion 2 07-13-2008 11:38 PM
OK to drill holes in top plate to run conduit? troll5501 Carpentry 4 05-11-2008 10:33 PM
Ball and Socket Joint Question lateralan Carpentry 9 04-25-2008 11:12 AM
The case of the hanging base plate KaiserS Building & Construction 4 02-02-2008 08:42 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
