Badly Cut Joist Help! - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-06-2011, 07:16 PM   #16
Registered User
Rewards Points: 4,894
If within 3' of the bearing wall, run a doubled header joist perpendicular to the joists. Cut the bad joist off about 6" to the right of the meter, if within 3', add a doubled one size smaller joist (as the span is only 20-28") so the bulk of the wires can go over the top of it (doubler). Follow these guidelines; http://publicecodes.citation.com/ico...002_par031.htm
Gary
Old 06-07-2011, 12:36 AM   #17
Originally Posted by Tizzer View Post
Has it been inspected?
not yet. They have to connect a few more wires and then set up an inspection, possibly this week.
nick1979 is offline   Reply With Quote
Cracks in joist clydesdale Building & Construction 4 01-04-2011 09:08 AM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 01:31 PM
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 09:00 AM
Jacking and Sistering Floor Joist Captain.Sassy Building & Construction 17 08-11-2010 02:30 PM
one rotted deck joist to replace, need advice dougq Building & Construction 10 07-07-2009 03:18 PM
