Backsplash Install - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-22-2011, 08:08 AM   #1
backsplash install
I'm using 1x4 poplar stained to match the cabinets for a backsplash on the counter top. My run is about 12 foot and my board is 10 foot when I make my splice with the 2 foot piece do I go with a standard 45 degree cut or use another angle? Would I be better off instead of using 10 and 2 to complete the run to use 8 and 4 or 6 and 6 pieced together?
RobertN is offline   Reply With Quote
Old 06-22-2011, 09:27 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
Buy a longer piece and make it up without a joint. How much can a 12' 1/4 Poplar cost?
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 06-24-2011, 10:48 AM   #3
Rewards Points: 5,336
A wood backsplash will be problematic with all the water. Where it comes into contact with the counter, you will have mold issues if it's not sealed properly.
Maybe even then behind the sink.
Ron
B. Franklin 1759
Delta-FL on floor and XPS on walls. Should I install the flooring or the walls first? yotaman Remodeling 11 04-19-2011 09:20 AM
Beadboard Backsplash nthomp16 Building & Construction 12 02-06-2011 03:28 PM
Should I install interior doors before floor? pttcc Flooring 13 11-23-2010 09:02 AM
Anyone install a tin/copper style ceiling? flashme18 Remodeling 7 07-19-2009 07:56 AM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
