Back Panel On Oven Cabinet? - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-29-2011, 04:30 PM   #1
Question
Back Panel on Oven Cabinet?
I'm installing a built-in oven in an 80" high pantry cabinet. The oven installation instructions say to allow a minimum cutout depth of 23 1/2". The cabinet depth is 23 3/4", but that includes 3/4" for the rear panel, so the interior depth is only 23". I can add a face frame if necessary, to provide another 3/4" of depth, but I'd rather not do that for aesthetic reasons (none of the cabinets have face frames now). Any reason I can't (or shouldn't) remove the back panel from that section of the cabinet? The wall behind the cabinet is standard sheetrock.
richp0 is offline   Reply With Quote
Old 06-29-2011, 09:08 PM   #2
Personally, I see no reason why you can't cut that out, unless it would affect the structural integrity of the cabinetry.which it shouldn't.
Stanchek is offline   Reply With Quote
Old 06-30-2011, 07:03 AM   #3
Rewards Points: 5,336
The rear panel is likely 1/4" thick. I've never seen a complete 3/4" back, only 3/4" cleats the cabinet gets attached to the wall through.
If you have to cut a cleat, I'd add additional bracing above the area, especially for a frameless cabinet at the end of a cabinet run.
Ron
B. Franklin 1759
Old 06-30-2011, 10:06 AM   #4
The rear panel is only 1/8" thick, dadoed into the side panels. There's a 4" wide by 5/8" thick cleat behind it, across the top of the cabinet. There's no cleat in the area where the oven will be mounted.
Old 06-30-2011, 10:58 AM   #5
Where is the cabinet situated? Cabinets on both sides or on the end?
If on the end(or free standing), I'd mount "L" brackets on the cabinet sides(4) and into the wall to keep the sides from splaying?
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
richp0 (06-30-2011)
Tags
cabinet , oven installation
Critique my Sub Panel rjniles Electrical 18 05-17-2011 11:31 PM
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
Oven lights on front panel not working bsmith95610 Appliances 3 03-20-2011 08:12 PM
removing the back panel on my freezer djsmom Appliances 1 03-09-2011 05:04 PM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
