Back Door On House Odd Size - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-04-2011, 02:11 PM   #1
Rewards Points: 87
back door on house odd size
My house was built in 1905 and the back door is an odd size. Its old and beat up, I wanted to put a steel door in but wasnt sure if i could cut the door down. The door is 75 inches tall and 29 5/8 wide. I wanted to put a 36" door.
Roundeye is offline   Reply With Quote
Old 05-04-2011, 02:41 PM   #2
you would have to open the wall and install a new longer header and new king studs and jack studs at 81-81-1/2 the door instructions should tell you the rough opening size. if its a load bearing wall you will need to support the ceiling joists with a temporary wall while you reframe the opening.
Old 05-04-2011, 03:00 PM   #3
Rewards Points: 87
I guess I shouldve mentioned that I cant put a taller door in, the door way goes from the floor to almost the roof. Thats why I wanted to know if I could cut the door down.
Old 05-04-2011, 04:04 PM   #4
Rewards Points: 5,336
You can order metal doors cut to size within limited parameters. Doing it yourself would not be my choice.
Check with the local lumberyard.
Ron
Old 05-04-2011, 04:19 PM   #5
A door a day is all I ask
TheDoorGuy's Avatar
Hi there,
I think a fiberglass door would be the better choice.
No rust, no dents and looks nicer.
You could get a 30 x80" door. They come in at about 29 13/16 x 79.
Cut it down in height a put in new bottom (or top) and you can plane a
little off the sides to get down to your width.
As Danny said the wider door will require new header and reframing.
Best of luck with the project!
RC/DG
Richard The Door Guy
www.thedoorguy.com
TheDoorGuy is offline   Reply With Quote
Old 05-09-2011, 02:47 AM   #6
Why not take into consideration the Pocket doors? I bet it will look good on your unussual size door.
charlenej is offline   Reply With Quote
Old 05-09-2011, 06:14 AM   #7
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Pocket doors are not designed for exterior applications.
Steel doors rust over time.
Fiberglass is a good choice as well as another new wood door.
tcleve4911 is offline   Reply With Quote
Old 05-09-2011, 07:46 AM   #8
Please let us know how you would frame a pocket door opening in an exterior load bearing wall.
Ron
Old 05-09-2011, 04:30 PM   #9
DIY_Diva's Avatar
ETO Doors in LA (they also sell online) sells custom doors
http://www.etodoors.com/custom-doors
DIY_Diva is offline   Reply With Quote
What would cause back graded water pipes on a 3 year old house. steveo333 Plumbing 7 11-08-2010 09:32 PM
awg size for 60' underground line from house to shed for 60 amp capslock Electrical 5 06-09-2010 10:31 AM
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 05:42 PM
Sloping Floor and back half of the house. Help! mikeinfrisco Building & Construction 1 01-22-2005 08:50 AM
