Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 10-29-2011, 11:40 PM   #1
B&D Cordless Drill
The battery on my 12V Firestorm drill is about shot. Before buying a new 12V battery, I was wondering if it will accept an 18V battery. The base on both appear to be the same.
pgr380 is offline   Reply With Quote
Old 10-30-2011, 08:21 AM   #2
journeyman carpenter
woodworkbykirk's Avatar
B&D Cordless Drill
its very unlikely.. the only cross compatibility with cordless tools these days are some models will accept the same voltage in both nicad and lithium ion
woodworkbykirk is offline   Reply With Quote
Old 10-30-2011, 12:40 PM   #3
Framing Contractor
B&D Cordless Drill
It doesn't work. I have the 12v and a coworker has the 18v.
sixeightten is offline   Reply With Quote
Old 10-31-2011, 03:36 AM   #4
sdsester's Avatar
B&D Cordless Drill
Trying to overpower an electric motor, whether with battery or real juice, has to end badly. And if you happen to think you can hold it while you try?
I guess low voltage tools will not hurt you? Plastic might feel a bit hot in a 12v tool stuffed with an 18v thing?
sdsester is offline   Reply With Quote
Milwaukee M12 cordless drill/driver/hammer drill - enough for the job? snosurfa7 Tools 8 12-05-2010 10:51 PM
Need advice on cordless drill brand with a battery life of over 5 years?? stanlam Building & Construction 7 08-09-2010 12:31 PM
Broken caliper bolt chrissyb Automotive Repairs 12 12-28-2009 04:18 PM
Cordless Drill Batteries MrBill_DIY Tools 11 01-15-2009 05:17 PM
Best cordless hammer drill for occasional use jaym3 Tools 6 11-11-2007 08:26 PM
