Axis Line - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-07-2010, 05:35 PM   #1
axis line
Ive got a small job to lay out and the exterior walls are old and covered in plaster.I want to get an axis line so i can pull alot of measurements off it.
Whats the best way to go about this?
THX
ron08 is offline   Reply With Quote
Old 10-07-2010, 06:21 PM   #2
kwikfishron's Avatar
Rewards Points: 414
If you’re trying to find a stud pull off a outlet cover and it’s probably on the left side of the box. You can pull a layout from there.
kwikfishron is online now   Reply With Quote
Old 10-07-2010, 07:37 PM   #3
Originally Posted by kwikfishron View Post
If youíre trying to find a stud pull off a outlet cover and itís probably on the left side of the box. You can pull a layout from there.
No thats not the prob.Im laying out the plan,im going to snap lines on the floor for building walls for rooms and hallways.I just want a good straight line from 1 end of the floor to the other.The exterior walls are old and are not the best to pull measurements off and i dont think there stright either
Old 10-07-2010, 08:24 PM   #4
Registered User
Rewards Points: 5,498
The baseboard should be nailed directly on the plaster grounds, the straight board (horizontally) at the top of floor line to screed the wet plaster to. The studs were usually green or rough milled with the plaster varying in thickness according to the window jambs, door jambs, and plaster grounds used with the lath. Use a laser square if fine tuning that close.
Gary
Gary in WA is online now   Reply With Quote
Old 10-08-2010, 07:29 AM   #5
Rewards Points: 414
I’d pull a string line across the room where I think is should be then take multiple measurements off different points in the room adjusting the string until I was satisfied then pull another string 90 deg to that and there you go.
Capacity loss with line size Einride HVAC 1 06-29-2009 03:10 PM
Add natural gas line Tukeeman Plumbing 11 12-01-2008 07:53 AM
Condensate Line schott HVAC 17 06-02-2008 03:16 PM
Electric Line Under Ground Crazy Legs Electrical 9 04-15-2008 10:07 PM
Mutiple phone line needs an answering machine Densplace Electrical 5 04-04-2008 10:35 PM
