Automatic Garage Door Opener - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-24-2010, 10:56 AM   #1
I have a 24' x 24' garage. The two garage doors are 8' tall. My problem is the clearance of the garage door and the trusses is minimal to say the least.
The only way I see that I can install the two openers is to notch 2 or 3 trusses to get the necessary clearance for the rail.
If this is the only way.....I would of course bolt 2x4 supports on both sides of the notches.
Is there any other way to do this?
Rick
rickloftin is offline   Reply With Quote
Old 09-24-2010, 11:25 AM   #2
Rewards Points: 558
A residential garage door requires a minimum of 4 1/2Ē of headroom space. Your garage door system may need a low-headroom track system or a low-headroom-torsion rear-track system. For a garage door opener, you will need slightly more headroom (about 6 1/2Ē minimum). Call an overhead garage door company for a quote on that system.
epson is offline   Reply With Quote
The Following User Says Thank You to epson For This Useful Post:
rickloftin (09-26-2010)
Old 09-24-2010, 11:29 AM   #3
Rewards Points: 40
I assume you have an 8 foot ceiling.Can you exchange these doors for 7 foot?
daveb1 is offline   Reply With Quote
The Following User Says Thank You to daveb1 For This Useful Post:
Old 09-24-2010, 04:58 PM   #4
firehawkmph's Avatar
Rewards Points: 1,898
Rick,
Liftmaster makes a residential jackshaft operator that mounts off to the side.
http://www.liftmaster.com/consumerwe...px?modelId=834
Mike Hawkins
firehawkmph is offline   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
Old 09-24-2010, 05:45 PM   #5
You can't notch trusses
They are designed as a one piece engineered assembly
The Following User Says Thank You to Scuba_Dave For This Useful Post:
Old 10-04-2010, 12:43 PM   #6
Thumbs up
Thanks Epson
Thank you for the info. I'll contact someone locally.
Old 10-06-2010, 04:40 AM   #7
Originally Posted by firehawkmph View Post
Rick,
Mike Hawkins
saw that in action at the local Home Show recently. Its VERY quiet and it's not much more than a standard opener. Cool product, it gets my vote.
acerunner is offline   Reply With Quote
The 12-Gauge Garage Jack Olsen Project Showcase 28 07-08-2012 10:21 PM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 10:39 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 04:57 PM
Garage with sidedoors ....automatic opener handyd123 Electrical 1 09-03-2008 06:58 PM
