Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 03-19-2007, 11:01 PM   #1
Power Gen/RS Engineer
Default Atypical Hollow Metal Door/Frame Height
Hey kids-
In my super crazy house, the rear basement door to the outside is kinda "cousin Itt" short, like 72" tall, and very "cousin Itt" ratty as well. I'd like to replace it with a steel door and frame but I've noticed that most doors are only available in standard heights, i.e. 6'-8". Question is, can I special order the frame and door at a custom height or is it up to the installer to field modify? If custom orders are no biggie, is this something that you can get through the BORG??!
Thanks!
Jimmy
Think of how dumb the average person is. Now remember that half of all people are dumber than that-George Carlin
BigJimmy is offline   Reply With Quote
Old 03-19-2007, 11:17 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Originally Posted by BigJimmy View Post
Hey kids-
Thanks!
Jimmy
This is not as easy as it sounds. For one, you generally cannot properly 'field-cut' steel entry doors and have a weather-tight sealed entry.
Recently (about 6 months ago) we had to do an order of 7 'custom sized' (all different dimensioned) steel doors with frames for an older apartment complex.
I spent alot of time going through the different suppliers (Commercial and residential) that we normally do business with.
We eventually ended up going with H.D. (Believe it or not) .... because they offered the most flexibility for our needs (door width, frame length, door size = all being compatible) . Based on the measurements that you provided...I strongly suggest that you get your PRECISE measurements, wall width, inswing direction, bore out design, and give them a try.... (Special order it)
- Build Well -
More On This Topic
Hi, I'm Gary for Expert Village. You see our pictures are pretty much the same size. I just want to make one more edit and take off some of the edges on this pictures because it's a little bit wider than the second picture. And when the frames, the... Read More »
Rodents such as mice and rats, are most likely to enter a building as the weather turns colder and frost starts. Their outdoor habitats may not protect them from the weather and their food source runs low as well. They are attracted to the heat within a... Read More »
Part 1 - Learn how to adjust guitar pickup height to setup a fender stratocaster electric guitar in this diy guitar tech video. Read More »
One area where homes are less energy efficient is around doors. Many older doors leak around their edges, and many others are simply not insulated enough to provide good energy efficiency. Making doors energy efficient is one of the most obvious ways to... Read More »
Part 2 - Learn how to adjust the guitar string action to setup a fender stratocaster electric guitar in this diy guitar tech video. Read More »
grounding pole building sheet metal? borderbuster Electrical 2 07-08-2007 04:11 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
