Attic Storage Area Is Open To Chimney - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-20-2013, 11:39 AM   #1
Rewards Points: 20
Attic storage area is open to chimney
This is an upstairs attic storage area that I have decided to close in. It is or was open to the rafters so I have just added a ceiling and drywalling it in and now doing the mud part.
But another sidewall has about a 18 x 18 opening to rafter area where the chimney goes up. In there is mounted a transformer with a source of power which I have always assumed powers the door bells.
Several years ago, rats gone in up there and made a mess and they probably made entry through this opening, the ceiling area or a drain pipe that comes in at the floor. I think I have two problems to solve.
1. drain pipe...can I stuff insulation in the hole around the pipe and shoot some of that foam insulation to seal it?
2. How best to seal up this door bell transformer next to the chimney. chimney is not used...gas logs. I could either leave it as and build a trap door for access with 1x2s to frame it. Or, I could pull the power and transformer into the interior and close off the 18 x 18 hole all together.
Suggestions appreciated.
hunt4cleanair is offline   Reply With Quote
Old 05-20-2013, 11:58 AM   #2
GBrackins's Avatar
Rewards Points: 2,108
whatever you decide to do you should leave an access way from you storage under to that portion you have closed off. The requirement from the building codes I am under (yours may vary) requires a minimum rough opening of 22" wide x 30" high when located in a wall. This is required (in my area) if the enclosed area is more than 30 square feet and has a vertical height of 30" or more as measured from the top of the ceiling framing members to the underside of the roof framing members.
I would seal any penetrations with either fire retardant spray foam or rock wool insulation. Either will seal any opening to prevent the spread of fire.
Hope this helps.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Wrap chimney in attic? HankMaine Insulation 11 01-08-2013 08:13 AM
Newbie questions on refinishing walkup attic with knee walls FileOpen Insulation 2 11-19-2011 11:31 PM
Help with complicated insulation project in attic OhmZoned Insulation 12 11-19-2011 08:49 AM
Adding insulation and storage to Cape Cod Side Attic turin39789 General DIY Discussions 5 11-08-2010 10:50 AM
OSB flooring for attic storage? echase Building & Construction 1 03-25-2010 06:00 AM
