Attic Stairs - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-15-2011, 11:45 PM   #1
Attic stairs
I removed the old staircase that led up to the attic in order to access plumbing/electrical behind them. Now that I have a rough opening I can't decide to rebuild the stairs or install insulated pull down stairs and free up some floor space. Anybody have thoughts on this?
Cliffrock is offline   Reply With Quote
Old 09-16-2011, 12:30 AM   #2
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
A picture might help, but I suppose the main consideration is how often you need to access the attic and why.
The Following User Says Thank You to Blondesense For This Useful Post:
oh'mike (09-16-2011)
Old 09-16-2011, 10:11 AM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 596
How often do you go upstairs?
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 09-16-2011, 10:51 AM   #4
I have a pic but am not sure how to post it. I tried attaching it and it didn't work. Any advice?
I plan on putting a couch, T.V. and desk in the attic so when weather permits it can be a livable space. So I'll want to access it a couple times a week at least.
Old 09-16-2011, 11:07 AM   #5
Stuck in the 70's
I'm no expert, but it sounds like you will be turning it into living space, and as such will have to get into permits, codes, etc. as you may be adding weight it can not handle. You will most likely be required to have a standard staircase to meet those codes. A spiral staircase may be an option (depending on local codes), but have fun getting furniture up there.
Old 09-16-2011, 11:55 AM   #6
Ole Wood Worker
BigJim's Avatar
Rewards Points: 596
I think it has pros and cons either way you go. You could put a pull down in and if you didn't like it you can change it much easier than building the stairs then deciding on a pull down. If it were mine I would go with the stairs as a pull down wouldn't work for me, I would trade off the extra floor space for a stairs. How will it affect the resale value of you home, how safe is it in case of a fire, will it be safe for your family members?
As for inspection goes, I don't think they will allow you to have a pull down and use it for a living space.
Jim
Old 09-16-2011, 02:48 PM   #7
Local code has a ceiling height requirement that my attic doesn't meet so thats not an option. I would essentially be "storing" a couch, T.V. and desk up there. Would it be harder to carry furniture up a set of pull downs?
Old 09-16-2011, 06:19 PM   #8
Ole Wood Worker
BigJim's Avatar
Rewards Points: 596
It is tough just climbing a pull down, with anything in your hands would really be tough. Pull downs get pretty shakledy after a while and I don't trust them too much. I would go with the regular stairs for my choice.
Jim
Attic project - Would like opinions whataboutj Insulation 6 06-29-2011 03:07 PM
Attic stairs roundcorners99 General DIY Discussions 1 12-04-2010 06:56 PM
Ideal drop down attic stairs bentnails General DIY Discussions 3 11-18-2010 06:10 AM
Attic insulation over the cavity above the stairs jkocher Building & Construction 5 10-15-2010 09:03 AM
wiring code w.r.t. NEW folding stairs in garage attic fredsterl Electrical 4 09-25-2009 11:05 PM
