Attic Staircase - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-12-2009, 08:49 AM   #1
Attic staircase
Any recommendations on the best brand for a new attic staircase?
Going to be installing staircase so I can have storage in the attic.
My joists are 2x6., The staircase lenght will be perpendicular to the joist.
I will have to remove two joists.
Will 1 2x6 for a header be enough, or should I sister a pair of them for the headers?
I also read somewhere that the full joists (king studs?) the header is perpendicular to may be sistered. Not sure about this.
There is no ceiling up right now, so all I'm doing is framing the rough, will install after eiling goes up. Is the the right order of installation?
sharp is offline   Reply With Quote
Old 12-12-2009, 11:47 AM   #2
2X6 joists? whats the span? Hope its less than 8' especially if you want to use it for storage.
We double all four points.
II Weeks is offline   Reply With Quote
Old 12-13-2009, 06:18 AM   #3
What he said, no single headers. If it runs perpendicular to joist direction, screw a temporary 2x6 to the top of all the joists for support before you cut anything.
Old 12-13-2009, 10:11 AM   #4
Pro
there are some really nice units out there, but the price is up there too. regular ones are around 150-200 bucks and i think werner and louisville make them in several different opening sizes. i usually frame them for a 25-1/2"x54" rough opening. that seems to be common size.
double framing all around
ClemS is offline   Reply With Quote
Old 12-13-2009, 10:40 AM   #5
i would suggest sistering 2x8 to10 to all the joist. 1-where you putting isolation, 2 if you plywood for storage you will not get much inso in 2x6 pocket, 3- you will store too much stuff with easy access. Or you may be able to get more height and some structural integrity by going perpendicular with 2x6 stiffbacks
Raccoons in the attic electricpete Pest Control 17 05-12-2011 04:02 AM
Recently Topped Up Attic with Blown Insulation...Now I have Frost/Condensation earthad1 Building & Construction 81 02-18-2011 12:42 PM
Finished attic humidity? kcrossley2 HVAC 2 08-11-2009 05:06 AM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 02:28 PM
Attic Frost cougar01 Building & Construction 5 01-28-2009 08:33 AM
