Attic Ladder - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-29-2013, 06:15 PM   #1
attic ladder
hi, i have a werner w2110 attic ladder- for 105'-124" ceilings. can i cut down to fit 89" ceiling?
rissa is offline   Reply With Quote
Old 04-29-2013, 07:50 PM   #2
Roofmaster
Rewards Points: 2,172
105 feet?! Now thats a Ladder! Sure i would think you can cut it down, as long as you can re-install the ends, and as long as you can cut it exactly even. Look at it close and make sure you consider everything.
Old 04-29-2013, 08:34 PM   #3
thanks! that's what i was thinking.
Old 04-29-2013, 11:43 PM   #4
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Post #1 has an apparent typo.
I believe that he has a Werner Attic Ladder
that is built for ceiling heights from 10'5" to 12'
and he wants to cut it down for a lower ceiling height
Disclaimer
& Stay Safe
.....Bob Lavery
Old 04-30-2013, 07:04 AM   #5
yes bob, that's correct.
Old 04-30-2013, 07:39 PM   #6
Old School
Willie T's Avatar
Just be aware that the last step might be only a few inches off the floor. No big deal, but it throws some people off when they decend to the bottom of the ladder and are almost at the floor. If you remove that offending step, then you end up with an extra long reach at the bottom for the first step. Again, just something to keep in mind.
Willie T
Old 04-30-2013, 08:27 PM   #7
good thinking, i'll have to check on that.
Attic insulation suggestions? iwfur25 Insulation 1 07-09-2012 11:50 AM
Telescoping attic ladder rjniles General DIY Discussions 6 04-05-2012 08:06 PM
Attic project - Would like opinions whataboutj Insulation 6 06-29-2011 03:07 PM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 10:50 PM
Attic Ladder suggestions jdp72 Carpentry 5 11-15-2006 07:06 AM
