Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 05-29-2012, 10:52 PM   #1
Attic folding stairs need tweak
Whoever install the 3-section folding stairs to my attic, or the manufacturer, managed to make it so that the final section, when it folds out and contacts the floor, is separated from the middle section by about 3/8". Thus, when you step on the contraption, it bends passed where it should be, putting all the stress into a single line of contact with the section above it; it's hyperextended, like - we hope this never happens to you - an elbow or a knee.
I have temporarily glued 2 pieces of wood, on for each side, to the lowest step section, and this kind of works. It still allows a little play.
Any suggestions?
TIA
JeffT is offline   Reply With Quote
Old 05-30-2012, 04:39 PM   #2
cortell's Avatar
A picture is worth a thousand words...
cortell is offline   Reply With Quote
Old 05-30-2012, 05:37 PM   #3
It was a dark and stormy
Yoyizit's Avatar
Yes and if you modify it the manuf. can disclaim liability.
Old 05-31-2012, 02:06 AM   #4
Replace it. Nice ones with metal ladders and doors that seal are not expensive. I got one at HD for just over $100 and R&R by myself only took about 2 hours, probably less with a helper. So much safer!
Jrrckd is offline   Reply With Quote
Tags
attic, folding, stairs
attic stairs for attic hvac installation scrolup HVAC 1 04-15-2012 01:53 PM
Newbie questions on refinishing walkup attic with knee walls FileOpen Insulation 2 11-20-2011 12:31 AM
Raccoons in the attic electricpete Pest Control 17 05-12-2011 05:02 AM
Attic insulation over the cavity above the stairs jkocher Building & Construction 5 10-15-2010 10:03 AM
Attic Ventilation Question handy man88 Roofing 10 02-12-2010 11:50 PM
