Attic Flooring Question - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-27-2011, 03:20 PM   #1
Attic flooring question
Hi Guys,
I am going to install some R-13 in my attic and then some OSB for the floor. The studs are 24" on center, so will 7/16 thick OSB be sturdy enough or should I install something thicker?
Thanks in advance,
Chris in Las Vegas
tinytr is offline   Reply With Quote
Old 08-27-2011, 04:34 PM   #2
AGWhitehouse's Avatar
Originally Posted by tinytr View Post
Hi Guys,
Thanks in advance,
Chris in Las Vegas
R-13 sounds a little thin...
You won't like the spongy feel of 7/16" osb at 24" span. I'd go with 5/8"min.
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 08-27-2011, 04:39 PM   #3
Thanks for the tip.... I was wondering about the "bounce" of the floor due to the 24" between studs.
Going with R-13 just under where the floor is going becuase the opening below the studs is 3.5". I should have mentioned this is a garage attic with 0 insulation presently. Once I have enough floor space for storage, the rest of the attic will be R-30.
Old 08-27-2011, 05:25 PM   #4
DIY staff
Rewards Points: 7,174
What is the framing (ceiling joists) ? Why a floor?
Very few attics are strong enough to even use for light storage---24" centers?
Old 08-27-2011, 07:16 PM   #5
Too Old
Those are not studs they are the bottom cord of the truss. You need to watch how much you put on the bottom cord it is not designed for much of a load. I have seen them sag and break you should have a stamp on the bottom cord that gives manufacturer and rating.
"Yeah, it's a nice garage, but you have to keep it heated at all times so it doesn't mess up your roof line."
havalife is offline   Reply With Quote
Attic project - Would like opinions whataboutj Insulation 6 06-29-2011 03:07 PM
Attic flooring - OSB or Plywood tariqk Building & Construction 6 10-20-2010 11:25 AM
attic insulation question justin76 General DIY Discussions 6 01-23-2008 01:28 PM
Attic Venting/Insulating Question gregt848 Building & Construction 1 11-25-2007 02:33 PM
attic insulation question dderolph Building & Construction 10 11-03-2007 05:21 PM
