Attic Floor - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-24-2013, 05:12 PM   #1
Rewards Points: 878
Attic Floor
We just put insulation down in the attic and wanted to put a floor down so that when we do go up, even if only 5x's a year, it would be easier to move around and store stuff. Can we put plywood over the insulation? I would not make sure I don't enclose the lights
Mstrlucky74 is offline   Reply With Quote
Old 02-24-2013, 05:26 PM   #2
Solutions (handyman)
Rewards Points: 364
Attic
Yes, you can do as you suggest. The key is to make sure the attic is insulated to the proper R factor (I believe it has been increased to R-50) ... check with your local building inspector. This might creat a problem because R 50 is a lot of insulation. The attic floor should be above the insulation for the insulation to do it's work. Also, ensure the venting is adequate, both at the soffit level and your roof vents. An inproper balance can create issues.
Mark Harvey is offline   Reply With Quote
Old 02-24-2013, 10:53 PM   #3
Westies
Attic Floor
I've thought about that too and you have even more headroom.
One problem besides the effects of attic heat and cold (and occasional condensation) on your stored items even in boxes...insulation dust. My experience with the yellow batting is that it throws a lot of micro fibers, not sure if that's always true.
I dropped the idea here.
Westies is offline   Reply With Quote
Old 02-24-2013, 11:12 PM   #4
Would you be attaching the plywood to framing or just laying it on top of the insulation. It looks like the insulation is above the framing. If this is true every time a person or an item being stored was on top of the plywood it would be smashing the insulation and there for making it much less effective.
FrankSmith is offline   Reply With Quote
Old 02-25-2013, 04:43 AM   #5
Rewards Points: 878
Thanks guys. Starting to think it might not be such a great idea even if not attaching to the framing
Mid span bridging lylsutherland Building & Construction 2 10-29-2012 11:10 PM
Building Knee Walls in the Attic Jimmybrp Building & Construction 12 12-23-2011 01:22 PM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
Insulating attic floor AND rafters? John FX General DIY Discussions 11 10-10-2008 10:50 PM
How do I get from the upstairs attic down to my 1st floor? diyintexas Electrical 8 09-29-2008 05:05 PM
