Attic Ceiling Joist Install Question - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-26-2013, 04:42 PM   #16
sparks1032's Avatar
Please keep us up to date as I live near Chicago and was thinking of a similar project!
sparks1032 is offline   Reply With Quote
Old 02-26-2013, 09:27 PM   #17
AHH, SPANS!!!
Rewards Points: 1,166
sometimes when someone mentions 2x6 and built in 1903, that 2x6 might be 3" thick and up to 7" wide. that fits into the equation also.
hand drive is offline   Reply With Quote
Old 02-27-2013, 11:39 AM   #18
Had an engineer come out... he was indifferent.
Said " floor is a bit bouncy - but nothing i put up there would end up in the living room if i left it as is".
His suggestion was to sister the 2x6's in one part of the attic (where the master bed would be) based on a 14 foot span of the floor joists.
Im can feel the floor bounce as is - so im going to sister them to be sure to do this project right.
I have not gone over specifies with the SE yet - but from what you guys know - does as sister have to span the full length of the joist span or will a sister in the mid-section of a joist provide added stability?
not even sure if a mid-section sister/non full span would be classified correctly as a "sistered" joist so apologies if I am using the incorrect terminology.
spaceboy is offline   Reply With Quote
Old 02-27-2013, 09:46 PM   #19
AHH, SPANS!!!
it is always best to span full distance for bearing purposes at the end of the joist member and onto a wall. Also,raising the ceiling to level (jacking up) before sistering gives a more solid floor without the bowl effect.
Old 02-27-2013, 10:10 PM   #20
Rewards Points: 150
Always sister full span but remember if it matters new conventional lumber isn't going to be as wide could be an 1/8 to a1/2 in different
kaschmid3 is offline   Reply With Quote
Old 02-28-2013, 07:01 PM   #21
Registered User
Rewards Points: 526
Pages 136-145; http://books.google.com/books?id=1uY...lywood&f=false
Gary
Newb DIY'er -basement drop ceiling question mike dub Remodeling 3 02-18-2013 07:37 AM
Garage ceiling joist, bracing, and insulation ACR_SCOUT Building & Construction 11 01-21-2013 06:05 PM
Ceiling Joist Size russ_mc Building & Construction 7 02-24-2012 04:06 PM
Attic joist cross beams & moving them Fox Building & Construction 11 04-02-2010 08:48 PM
correct joist size for attic helpless handyman Building & Construction 1 07-05-2006 11:29 PM
