Attaching Wainscoting Directly To Studs Or Drywall? - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-03-2012, 08:43 AM   #16
Don't remove the drywall just build out. I would rabbit the edge of the 1x6 to fit the beadboard; if you cut the beadboard insert to fit inside a rectangular frame that might not be square then there will be a bad gap at the beadboard/1x6 joint, the rabbit will allow you to cut the board 1/2" longer than what you want to be seen and then it will hide any gaps.
brockhouse is offline   Reply With Quote
Tags
wainscoting walls
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 09:42 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
5/8" drywall on steel studs 24" OC Charles_cz Drywall & Plaster 11 06-08-2009 08:39 PM
Attaching kitchen cabinets directly to studs with no drywall between nrabate Carpentry 7 08-28-2007 09:01 AM
Maxx Shower Walls Install on Metal Studs? atilla137 Plumbing 2 11-21-2006 06:17 PM
