Attaching Top Plate To Existing Ceiling - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-29-2009, 02:21 PM   #1
attaching top plate to existing ceiling
If I am fastening a top plate for a new closet in an open part ot the room how do I fasten it to the ceiling? Do I cut away the drywall to expose the joists and attach the top plate on and stick frame the rest of the wall in or do something different?
derek9 is offline   Reply With Quote
Old 07-29-2009, 06:06 PM   #2
Rewards Points: 1,910
You can put it directly over the existing drywall and nail through into the ceiling joists. Sometimes you'll need to put blocking between the joists to have something to nail into but that can be done from the attic.
You can nail the top and bottom plates in place and then toenail in the studs or you can build the wall and tip it up. If you tip it up you'll want a double top plate but don't nail the upper top plate on the wall assembly and then try to tip it up cause it will jam before getting upright. Instead nail the upper top plate on the ceiling. Then you can tip up the wall (because you have that extra 1 1/2" room) right next to the upper top plate and slide it under the upper top plate and nail it in place.
Old 07-30-2009, 01:37 AM   #3
Rewards Points: 1,016
Don't make the assumption that the ceiling is level - meaning the floor to ceiling height is the same everywhere along where the the new wall is going. Check it before deciding to build the wall then tip it up into place.
Don't ask how I know to do this...
Old 07-30-2009, 11:37 AM   #4
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,312
For a non-load bearing wall, I'd use screws. They're easier to back out if you make a mistake.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 07-30-2009, 01:12 PM   #5
Derek, you should take a level to the ceiling where the new plate is going, and see if the sheetrock is flush or if its wavy. Even though it is only a closet, you still want to make sure that you get a nice tight connection to the floor joists above. If you have popcorn finish on ceiling, you may want to cut out, or scrape the area the new plate will sit.
When you sheetrock the closet, you will need to finish the seam at the ceiling no matter what, so even if you cut out some sheetrock, it won't make the finishing harded, since you already need to finish the top edge.
Additionally don't use screws to attach the top plate. Screws are easy to snap under shear pressure. Best bet will be to borrow or rent a pneumatic nailer. Will also go alot easier, especially when you do all your toe nail connections for building wall in place.
Green Giant is offline   Reply With Quote
Old 07-30-2009, 08:14 PM   #6
thanks
Thanks everyone for the info. All made sense and everything worked out perfect!!
New ceiling within an existing room? Is it possible bennett12 Building & Construction 3 07-10-2009 10:05 PM
Advice for installing ceiling fan Ceiling Fan Man Electrical 5 06-02-2009 05:18 PM
Framing a partition wall on existing carpet and ceiling tile? eagle86 Building & Construction 3 07-23-2008 04:39 PM
Ceiling Fan Installation kennykenny Electrical 14 07-08-2008 11:57 PM
