Attaching A Slatted Partition Wall - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-16-2012, 05:45 AM   #1
Attaching a Slatted Partition Wall
I would like to add a small poplar partition in between my living room and kitchen. The wall does not span the width of the room. I will need to attach it to the ceiling and the floor which is laminate hardwood. Any ideas on how I should do this? Here is what i want it to look like below.
http://www.houzz.com/photos/89832/Ur...room-charlotte
Thanks!!!!!!
evdie4 is offline   Reply With Quote
Old 07-17-2012, 12:07 PM   #2
Retired Cabinetmaker
woody4249's Avatar
Rewards Points: 156
I would use aluminum square tube framing system like the ones supplied by Outwater plastics
Go to www.outwater.com and search aluminum framing system
or
click on http://www.outwatercatalogs.com/sear...framing+system
This is a 1" square tube and you can also get the corner connectors for fast and easy assembly. Use at least three vertical posts so as to keep your slats straight.
Consider using a maple plywood and then edgebanding the edges with matching wood tape. Unless you use well seasoned lumber, the slats will tend to bow
Assemble the frame from floor to ceiling and attach the slats with a coach bolt and an acorn nut on the back.
If you don't want to fix this structure permanently, you can use a corner connector that has a thread for a adjustable leveler. Cut the aluminum frame a little shorter and install the levelers. Unscrew the levelers until the frame lifts and expands to the opening between floor and ceiling. Use rubber pads so that there is no chance of it falling or moving if pushed against.
We would use this method as store fixtures in clothing shops.
Mike
"I'm not as green as I am cabbage looking"
woody4249 is offline   Reply With Quote
Tags
parti
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Attaching patio cover to the top of cinder block wall robertwallace Building & Construction 7 07-10-2012 10:22 PM
Subfloor beyond partition wall hennetina Flooring 1 01-13-2011 08:16 AM
Adding a partition wall sheslostcontrol Carpentry 4 12-23-2010 07:53 AM
partition wall big rob Carpentry 12 08-22-2010 05:47 PM
