Attaching Pressure Treated Deck Boards? - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-15-2011, 09:47 AM   #1
attaching pressure treated deck boards?
My deck joists will be 12" OC, do I need to screw 5/4 pressure treated boards to each joist....this seems like a lot of screwing. Also, does anyone have information on stainless steel screws over the triple coated deck screws? The triple coated screws are $3/lb, and the stainless are $11/lb.
trimdoctor is offline   Reply With Quote
Old 03-15-2011, 09:55 AM   #2
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
What's your decking material?
Why are you going 12"o.c.?
You don't need to fasten to every joist but it will probably bounce as you're walking on it.
It also means you'll only be fastening every 24"
What's up with this method?
I hate SS. They're soft.
tcleve4911 is offline   Reply With Quote
Old 03-15-2011, 10:06 AM   #3
I'm using 5/4 pressure treated deck boards. I'm going 2x12 12" OC, because I like overkill and I dont like decks that are spongy. Also, it is a big deck and we I want it to be able to hold lots of people....we are party animals.
Old 03-15-2011, 04:42 PM   #4
Licensed Pro
kcremodeling's Avatar
If you don't want your deck to be spongy, don't use the 5/4 decking. You would be better of going on 16 O.C. and using solid 2x.
kcremodeling is offline   Reply With Quote
Old 03-15-2011, 07:21 PM   #5
Handyman
Rewards Points: 512
Yep, I agree. Only difference is you lose the bevel.
canadaclub is offline   Reply With Quote
Old 03-15-2011, 08:24 PM   #6
i would srew every board if the decking is wet it will eventually shrink and by not screwing every board may cause it to warp in a bad way
fulton 22175 is offline   Reply With Quote
Old 03-16-2011, 08:32 AM   #7
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
you're using 2 x 12 @ 12" o.c. ..what's your span?
2x6 decking would be a huge upgrade but not sure if you could get it in a select or better grade like you can with 5/4
If the bevel is of concern, a 5/16" roundover on a router works well....done it...do it all the time.....(that's another thread)
I'd frame it at 19 3/16" o.c. That's the perfect blend between 16 and 24 o.c
The nailing pattern is much more pleasing to the eye and you can get your a$$ and your tools between the joists.
Why 19-3/16".....?
Old 03-16-2011, 10:39 AM   #8
Cedar or pine?
16" OC and 2x6 is the only way to go. The 5/4 board just don't last as long in my opinion.
Use the coated screws, use pressure treat lumber. Screw at every joist.
Good decks are done right. Bad decks, cut corners during construction.
pjordan4477 is offline   Reply With Quote
Old 04-04-2011, 04:00 AM   #9
I ran into this problem. I should have left the screw heads above the deck surface until it dried out. Now they are loose and the heads will be below deck serface after tightening them up.
rodm1 is offline   Reply With Quote
The Following User Says Thank You to rodm1 For This Useful Post:
Fix'n it (07-08-2014)
Old 04-05-2011, 07:49 AM   #10
Rewards Points: 1,216
You say you overkill OK but don't skimp where overkill is needed nail/screw at every joist at Min of 2 screws about 1" in from edge. If using pressure treated lumber do not separate put tight next to each other because they will separate on their own when drying out and you will have a nice gap. You'll be glad you did.
COLDIRON is offline   Reply With Quote
Old 04-05-2011, 09:05 PM   #11
Rewards Points: 272
I did my sisters deck in late summer and returned to it late next spring to tighten it all up again and it is so strong she actually parks her Harley on it. I put a ramp at one end so she could keep it out of the weather.
cheers
fixrite is offline   Reply With Quote
Pressure treated wood does or does not need to be painted???? stanlam Building & Construction 11 03-27-2011 04:04 PM
Deck Access Hatch rman1953 Remodeling 7 07-11-2010 06:44 PM
Composite Deck Boards dgoodwin3364 Carpentry 10 06-05-2009 12:09 PM
pressure treated deck on flat roof hubble Roofing/Siding 2 05-30-2009 08:42 AM
Cedar Deck boards Outbacker Painting 2 03-04-2006 02:12 PM
