Attaching Pool Stick Holder Against My Unfinished Basement Concrete Wall - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-01-2016, 10:46 PM   #1
Rewards Points: 22
Attaching pool stick holder against my unfinished basement concrete wall
Hi
I need to stick a pool stick holder against my unfinished basement wall.
Will liquid nails work..?
If not can I just get those tapcon screws from HD and screw them into my smooth concrete wall?
To screw a inch, can I use a regular drill...? What drill bit to use?
I'm afraid I might get cracks from those holes in future...pls advice.
Sent from my SM-N910V using Tapatalk
Kris2001 is offline   Reply With Quote
Old 03-02-2016, 07:45 AM   #2
Rewards Points: 13,968
Tap-Cons would be best, going to need a hammer drill if you do not want to spend all day making those few holes.
A bit comes in the box of screws.
And no, it's not going to crack the wall.
I find the 1/4 screws hold the best, deeper threads.
Old 03-02-2016, 09:32 AM   #3
Rewards Points: 1,668
NP 1
http://www.bestmaterials.com/np1.aspx
SeniorSitizen is offline   Reply With Quote
Old 03-02-2016, 02:07 PM   #4
DIY staff
Rewards Points: 7,174
I agree with Senior Citizen---Adhesive---PL Premium will also work well----
I would glue a board to the wall--then screw the brackets to the board--the Q rack might not have enough glue area===and would need to be broken off the wall to remove it.
Kris2001 (03-02-2016)
Old 03-02-2016, 02:43 PM   #5
Rewards Points: 22
Awesome...Is it available in local HD, Lowes? Thx
Old 03-02-2016, 03:40 PM   #6
Np1
NP1 is the best at about $5.50-$6/tube....I have seen NP1 in Ace Hardware, Fastenal, and Richard's Supply, but I've never seen it in Lowes or Home Depot.
MrWigg is offline   Reply With Quote
Old 03-02-2016, 03:52 PM   #7
Rewards Points: 22
How strong is the bond...If I stick a plywood board to concrete wall. Then hang game stuff like dart board, pool accessories holders etc(not heavy)?
Old 03-02-2016, 04:22 PM   #8
DIY staff
PL premium is available at Menards and Home Depot--
Np1 or PL premium will be stronger than the wood---to remove the board, you will need a hammer and chisel.
Old 03-02-2016, 06:45 PM   #9
Rewards Points: 22
Thanks I'll buy whichever is available locally...NP1 or PL premium.what's better?
This is the plywood piece about 1.5x6 feet.seems like 3/4"thick.
So I guess I'll use less than an inch long screws to hang whatever I want.
Do I smear the edges randomly...How much to apply?
Do I brush the wall just to remove dust.
Importantly how to hold the board midway against wall until cured?
Thx
Old 03-03-2016, 07:17 AM   #10
Rewards Points: 788
I wouldn't get the wooden pieces on a concrete basement wall. Possible mold and warping.
carpdad is offline   Reply With Quote
Old 03-03-2016, 07:45 AM   #11
Rewards Points: 22
The house came with few 2x4 pieces nailed flat to wall . It has outlets. Been 12 yrs they look ok.
I also run a dehumidifier.
Old 03-03-2016, 12:54 PM   #12
Rewards Points: 867
Originally Posted by SeniorSitizen View Post
interesting stuff. site calls it a caulk/sealant. but you say it is a good adhesive also?
TimPa is offline   Reply With Quote
Old 03-03-2016, 03:37 PM   #13
DIY staff
The usual way is to use the 'dot and dab' method--on the back of the board---
add thick blobs of glue---far enough from the edge that the excess won't squish out to the edge---one blob in each corner---then additional blobs about 10" apart--
Press firmly against wall---prop something heavy against it to hold it from slipping until the glue sets up.
Kris2001 (03-03-2016)
Old 03-03-2016, 05:34 PM   #14
I would first clean the area and do a test piece like maybe 2"x2" in that area to determine if it will be satisfactory. When you remove it after curing you will know if it is satisfactory.
The Following 3 Users Say Thank You to SeniorSitizen For This Useful Post:
Kris2001 (03-03-2016), oh'mike (03-03-2016), TimPa (03-04-2016)
Old 03-03-2016, 07:05 PM   #15
Rewards Points: 22
I might just cut 2 pieces each 16"x10". Stick them as advised.one for top and one bottom for holding pool stick holders. Good idea?
Drilled Furring Strips In Basement Concrete Wall and Water started to weep through... marshallryan Concrete, Stone & Masonry 13 03-22-2013 04:29 AM
breaking up concrete near basement wall benleef Concrete, Stone & Masonry 12 02-12-2013 03:58 PM
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Attaching a worksurface directly to studs in of a basement wall BasementVirgin Building & Construction 3 10-06-2010 12:04 PM
Attaching bottom plate to concrete at edge near wall BlueBSH Building & Construction 13 06-13-2010 04:05 PM
