Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 04-02-2011, 09:36 AM   #1
Attaching picture frame molding to wall?
When attaching picture frame molding to the wall there isn't always a wall stud where you need it. What is your technique?
wihi69 is offline   Reply With Quote
Old 04-02-2011, 10:59 AM   #2
Carpenter
dtsman's Avatar
Liquid Nail or similar product?
Bo
Remember,
If the women don't find you handsome,
they should at least find you handy.
(Red Green)
dtsman is offline   Reply With Quote
Old 04-02-2011, 11:03 AM   #3
Jack of all - master none
hyunelan2's Avatar
I used liquid nails panel adhesive, and tack a couple of brads into it to hold it in place while drying.
Picture molding wainscot in foyer and stairway
hyunelan2 is offline   Reply With Quote
Old 04-02-2011, 11:19 AM   #4
I use liquid nail or latex/silicone caulk with a few brads.
Gizmoman is offline   Reply With Quote
Old 04-02-2011, 11:19 AM   #5
old guy contractor
tcleve4911's Avatar
I use Loctite Power Grab and maybe a few brads
There's one specifically made for molding and panels.
tcleve4911 is offline   Reply With Quote
The Following User Says Thank You to tcleve4911 For This Useful Post:
Willie T (04-04-2011)
Old 04-02-2011, 11:40 AM   #6
I used Elmer's wood glue and brads (nail two nails so that they cross like an X into the sheetrock; locks it in while glue dries), Elmer's is easy, cheap, and worked for me.
bob22 is offline   Reply With Quote
Old 04-02-2011, 12:33 PM   #7
Carpenter
Bob22 has got it. Nail it as you would into studs, but angle the nails at a few different angles. This will pin it to the sheetrock. If you are going to paint, the caulk you put around the edges will hold it sufficiently. If stained, glue it to the wall with any adhesive caulk and then nail it as stated above.
marttinen is offline   Reply With Quote
Old 04-04-2011, 06:40 AM   #8
Thanks Guys for your input.
Old 04-04-2011, 10:31 AM   #9
SteelToes's Avatar
This one works just fine...
SteelToes is offline   Reply With Quote
Old 04-04-2011, 10:37 AM   #10
old guy contractor
tcleve4911's Avatar
I used to used Liquid Nails until I found this Power Grab.
I like the way you can butter it up and stick it to the wall and it stays.
It's water soluble so clean up of the ooze out is easy.
Old 04-04-2011, 10:39 AM   #11
Old School
Willie T's Avatar
Almost anything Loctite puts out is hard to beat.
Willie T
Old 04-05-2011, 11:19 AM   #12
I put a 4'x2' frame around my in wall aquarium using liquid nails. It holds fine
carpenter981 is offline   Reply With Quote
Top plate for frame wall, quick ? NEW-B Building & Construction 7 03-18-2011 09:33 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Picture frame windows stockups General Discussion 0 03-04-2010 04:16 PM
how to determine if wall is load bearing Tonglebeak Building & Construction 26 01-21-2010 12:26 AM
Solidly Securing Picture Rail Molding? Lovegasoline Building & Construction 13 11-25-2009 03:13 PM
