Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 06-27-2007, 11:10 AM   #1
Power Gen/RS Engineer
Attaching Limestone Sills to Wood Framing
Hey there. I posted this originally in the construction forum but got zero replies. Any thoughts or advice would be appreciated!
I am getting ready to remove a panel of five existing single-sash windows in the front of my house. To add some character, I intend on installing 3 round-top casement windows in this opening with brick surrounds. I would also like to use limestone sills beneath each of the three windows. My house is balloon framed construction with stucco exterior.
My questions are as follows:
1. How would I go about connecting the limestone sills to the framing? I had considered drilling holes into the bottoms of the sills and epoxying threaded studs. Then I could drill corresponding holes in the wooden sills, set the sills and apply washers and nuts below to secure.
2. Do I need to install any sort of moisture barrier between the stone and wood to prevent water damage due to rain wicking into the stone?
Thanks in advance!
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves,"You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." - George Carlin
BigJimmy is offline   Reply With Quote
Old 06-27-2007, 06:12 PM   #2
carpentry
WNYcarpenter's Avatar
It seems like you have a decent knowledge of construction, your instincts seem right on so trust them...I don't see any problems with your attatchment idea. You are right about using a waterproof membrane to keep the limestone seperated from the wooden structure. I've never encountered this situation myself, there's good chance few have...anyway I was thinking a Z bend in metal flashing, one 90* covering the back side of the stone sill, and one 90* lipping the exterior stucco with the sides of the RO flashed with Ice and Water, or metal, set the sill in a large bead of silicone, especially around the bolts...my advice is certainly open to debate
I hope I've been of some help!
WNYcarpenter is offline   Reply With Quote
Old 06-28-2007, 09:44 AM   #3
I came across this site http://www.caststone.net/designer/ca...l.asp?CatID=24 you may want to ask them for installation instructions.
Jeekinz is offline   Reply With Quote
Old 06-29-2007, 08:43 AM   #4
Yeah, you're right all the way. This is like, construction 101 and I was having a brain toot thinking about the limestone. I'll definitely flash as recommended.
BTW: What is "Ice and Water?" Something similar to Tyvek?
Thanks for the advice, it was helpful.
Old 06-30-2007, 03:02 PM   #5
carpentry
Ice and water is a generic term...it's the adhesive underlayment used in roofing, WeatherSheild, and Grace just to name a couple. Comes in rolls like felt/tar paper.
There's all kinds of flashing products to choose from. I was just skimming through an article in a trade journal demonstrating a method used to flash a recessed window. www.fortifiber.com is the product website.
If you haven't already finished your project, a pictue would be nice to see.
Old 07-01-2007, 09:59 AM   #6
HA! I haven't even closed on the home equity loan! At this time, I'm just planning, getting my designs ratified and procuring some of the cheaper materials, like sills, face brick, lumber, etc. I like to plan thoroughly before any major undertaking, like this one.
Old 11-14-2008, 09:57 PM   #7
BigJimmy,
I am working on a project with an identical objective: attaching a limestone sill to 2x6 construction with stucco exterior. Did the threaded stud idea work?
blair.gardner is offline   Reply With Quote
Old 11-14-2008, 10:08 PM   #8
General Contractor
I completed a project similiar to yours recently. First of all, unless you have some support under the limestone you will have to use something like a limestone veneer. What we did on our stucco house was notch the studs so the stone could slip into the notch and add support. the stucco was 3/4'' thick so that added some support and the overall stone depth was 3-1/2" so we had a 1-1/2" projection. the stone was glued in place. The stucco came second and caulk last. It worked out well for us.
Illinois G.C. is offline   Reply With Quote
Old 11-14-2008, 10:11 PM   #9
Illinois et. al. - Do any of you guys have drawings you could upload? I'm having a hell of a time figuring out how I am going to attach the limestone with such a minimal depth of exterior sill (about 3 inches total.) I am thinking I might need an L bracket or something similar to screw into the plywood sheathing for support. Seeing drawings would be fantastic, even if they are quick sketches.
Thanks!
-blair
Attaching wood srtips to concrete wall DIY4EVER Building & Construction 11 07-21-2007 11:10 PM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 10:14 AM
Wood Framing Getting Wet? stagger19 Carpentry 2 05-10-2006 09:37 AM
Wood to Concrete without Drilling MattStata Carpentry 1 04-19-2006 05:16 PM
