Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 02-12-2007, 12:12 PM   #1
Attaching Carsiding
I am putting up carsiding for a ceiling in my attic. I am having trouble putting the pieces together. As I tap or pound to make the groove fit on the tongue I end up damaging the piece so then it makes the next piece difficult to attach. Any ideas on making my life easier?
cibula11 is offline   Reply With Quote
Old 02-12-2007, 01:22 PM   #2
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
Attaching Carsiding
Yea, use a scrap over the tongue to pound on. To make that eve easier rip it down to about 1 1/2 inch or so, that way it will fit in your pocket.
Brik is offline   Reply With Quote
Old 02-12-2007, 01:24 PM   #3
Handyguy
Brik's Avatar
Attaching Carsiding
Also, you may alread know this. If its going to show you can blind nail into the tongue at an angle so the next board's grove covers the nail head. When you are finished you have zero nail heads except at the outside edge of the first board.
Old 02-12-2007, 01:38 PM   #4
Attaching Carsiding
I have done all of this. And, still having problems. I was told to start with the groove down and tongue facing up. So for each piece I would put the groove into the tongue of the piece that is already hung. It's not a very smooth fit. They T&G fits very snug. Is there something I could lube it up with to make it work better. No puns please
Old 02-12-2007, 01:41 PM   #5
Attaching Carsiding
Nevermind...I have an idea that I think will work. I'm an idiot.
Old 02-12-2007, 01:51 PM   #6
Handyguy
Brik's Avatar
Attaching Carsiding
No lube. Probably whats happening is the studs you are attaching to are not all in line with each other. When you attach one piece it is forcing a slight bow so its not straight and the next board is. Or, your boards are bowed a bit forcing you to bend them to line up properly.
So, what can you do.
Get straight boards and attach them to straight studs. Probably not pracical.
So, you will need to deal with it. Are you hand nailing or using pneumatics?
If using pneumatics you can nail in the first board then use a pry bar to pull it off the studs by about 1/4" at each stud. Attache the next board then pound the face of the previous board to snug it down to the stud. Repeat for each board. By prying up slightly you will have more space to mauver each board into place.
If hand nailing do similar but do not nail the nail home so you have that play. Or do nail it and set the nail, then pry off a little as above.
When I have encountered this it is not usually every board, just a few. I try the regular way to fit in the next board first and only if I need to do I loosen the previous board a bit to make it fit.
One more thought - Take a couple of 12" long scraps. They SHOULD go together fine. If they don't it IS possible that the mill messed up and milled them poorly.
If that's the case then take them back for an exchange. If you cant do that then you may want to consider widening the groove a little. Reply back if you want a good technique for easily making the grove a little wider yet still ensuring its centered.
Old 02-12-2007, 02:16 PM   #7
Attaching Carsiding
Thanks...I will give it a shot. The pieces that I am working with are 12' so that doesn't help either. Shorter pieces have been fine, but I would like to keep my seams to a minimum.
More On This Topic
Hi this is Jon on behalf of Expert Village in this video clip I will show you how to remove your side trim boards. On this side we need to remove our gutter first before we can have access to our trim board. You need to unscrew where you gutter... Read More »
How to Frame a Wall
How to Frame a Wall by Expert Village
Hi! This is John on behalf of Expert Village. In this video clip, I will be showing you how to frame a wall. When you measure to cut your 2 x 4’s, make sure that you measure your wall and then you subtract 3 inches for your top plate and your sole... Read More »
So after you got your paint scraped and sanded just want to check your other problem area that we located in the beginning which would be this rotten wood over here on the back. Now when you are taking off rotten wood you just need a few tools because it... Read More »
Hi this is Jon on behalf of Expert Village, in this video clip I will show you how to prepare our wall studs. On our Styrofoam installation our wall studs fall behind this diamond line. In addition the studs falls where the Styrofoam pieces fit together... Read More »
This is Rob McMahon with ExpertVillage. Now, with a framing gun, there is generally two different, two different types of nailing styles that you use. One is through nailing which is preferable in most situations because it gives you the most strength... Read More »
Attaching Limestone Sills to Wood Framing BigJimmy Carpentry 8 11-14-2008 10:11 PM
Attaching wood srtips to concrete wall DIY4EVER Building & Construction 11 07-21-2007 11:10 PM
Attaching 4x4 posts to a concrete porch. dweagle Building & Construction 5 05-06-2007 06:22 PM
Attaching Sink to Vanity allen1466 Remodeling 4 06-02-2006 08:55 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
