Attaching 2X4's To Garage Floor - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-28-2007, 07:40 PM   #1
attaching 2X4's to garage floor
I'm building some utility shelves in my garage, and my plan includes securing several 2X4's to my garage floor. What are my options for securing them? I tried a powder-actuated nailing gun, and that just put a fat chip in the floor. Would a masonry bit and screws be my next bet? Other choices? Thanks.
Mr. Michael is offline   Reply With Quote
Old 02-28-2007, 08:00 PM   #2
yummy mummy's Avatar
Rewards Points: 1,016
I have put in 2X4s on my basement concrete using a hammer drill, and Tapcon screws.
I found that these really worked well.
yummy mummy is offline   Reply With Quote
Old 02-28-2007, 11:58 PM   #3
Darylh's Avatar
I have used these as well as tapcons and as well as a ramshot. They all have worked for me but I do like these in the photo the best but that depends on what I am doing. You drill a hole with a hammer drill and tap these into the hole. ASs you tighting the nut and washer agaist the 2x4 it spreads and tightens up.
Darylh is offline   Reply With Quote
Old 03-01-2007, 10:16 AM   #4
thank you both.
Old 03-05-2007, 01:44 PM   #5
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
Good advice on attaching the 2x to the concrete but I must ask WHY? Unless this is an island type cabinet I see no reason to attach to floor.
Brik is offline   Reply With Quote
Old 03-05-2007, 08:51 PM   #6
the 2X4's are 2 ft long, 3 attached to floor, the upright shelf supports are attached to the 2X4's.
Old 03-06-2007, 08:30 PM   #7
Extreme DIY'r Adk's, NY
Rewards Points: 272
maybe it's tall and he's really going to load it up...worried about tipping? I try to make everything moveable in my garage.. but one could certainly tie into a wall or ceiling much easier with the same result. I even put non load bearing partition walls in the basement w/ construction adhesive on the bottom plate and nail to the ceiling... unless you drove into it with a truck (in which case youd have bigger problems) it isnt going to move.
crecore is offline   Reply With Quote
Old 03-08-2007, 09:48 PM   #8
i am also using the wall as support. the ceiling is about 10-11 feet tall, and i didn't want that much height, otherwise i probably would have used the ceiling.
Recommendations for finishing garage floor? bhpizza Flooring 30 01-28-2011 11:09 PM
Blacktop on Garage Floor?? terrypearson Flooring 3 08-06-2007 08:05 AM
Raising Garage Floor to match House Floor felice_oggi Building & Construction 2 09-22-2006 08:26 PM
Garage Floor dustoff17 General DIY Discussions 2 02-28-2006 09:28 AM
Garage Floor leveling. Marsharo Remodeling 1 12-30-2005 03:11 PM
