Attaching 2x4 To Brick - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-11-2013, 01:40 PM   #1
attaching 2x4 to brick
I want to attach a 2x4 to a horizonal brick wall. This is to build a frame to secure lattice to one side of my carport. What is the best way to attach the wood stud to the brick so it will hold up to nails being driven in?
doubler1950 is offline   Reply With Quote
Old 04-11-2013, 02:16 PM   #2
I was disappointed recently when I read that a popular construction adhesive only lasts 20 years, so I'd use something other than that.
Dorado is offline   Reply With Quote
Old 04-11-2013, 02:41 PM   #3
adhesive
Thanks I was thinking maybe cement nails but it is really hard to get them in
Old 04-11-2013, 03:39 PM   #4
Rewards Points: 502
Why not just drill and plug with screws?
As you say the masonry nails are not that predictable.
tony.g is offline   Reply With Quote
Old 04-11-2013, 08:01 PM   #5
Roofmaster
Rewards Points: 2,172
Tapcon screws in the mortar joints. Put a serpentine bead of urethane sealant on the back before screwing in.
Old 04-11-2013, 08:33 PM   #6
Framing Contractor
Rewards Points: 118
Using screws to attach the lattice would also help. The vibration from the blows with the hammer can cause your fasteners to come loose. Tapcons and glue on the wood to masonry.
sixeightten is offline   Reply With Quote
Old 04-11-2013, 10:38 PM   #7
Too Short? Cut it Again!
I would use a masonry bit and drill for anchors into the brick, not the mortar. Insert the masonry anchors and then screw into them. I would be worried if the lattice wobbled around the fasteners in the mortar could cause the joints to deteriorate. The bricks should be more solid.
Admittedly, overkill perhaps.
Old 04-12-2013, 05:09 AM   #8
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,112
adhesive alone will fail over time, you need to use a mechancial fastener as well. either using tapcons, or plastic sleeve anchors for brick
woodworkbykirk is offline   Reply With Quote
Old 04-12-2013, 07:20 AM   #9
Maybe plastic anchors inside but outside the temperature extremes will cause them to fail. I would use lead/zinc metal anchors.
And don't underestimate the wind loads on something like a plant covered trellis. You can end up with quite a bit of "sail effect" yanking at or trying to sheer off the fasteners even though the trellis itself may not weigh that much.
Old 04-12-2013, 02:04 PM   #10
thanks
Thanks, there won't be any weight except yhe tresllis itself. I do want to go with something sturdy though. Many thanks.
Old 04-12-2013, 02:07 PM   #11
Rewards Points: 192
Tapcon brand screw will work or you can use sleeve anchors or the brand name Hilti bolts like below.
bcgfdc3 is offline   Reply With Quote
Old 04-12-2013, 02:07 PM   #12
Thank you
Appreciate your answer. I was actually thinking of using sleeve anchors,but as anothe rguy said I guess the cold might affect them so it will be medal anchors.
Old 04-12-2013, 02:08 PM   #13
Part of what I needed to know was what to drill into. Thank you so much.
Old 04-12-2013, 02:10 PM   #14
thanks
Makes sense to me. I'll try screws instead.
Attaching a bamboo screen to a brick wall. Jen23 Landscaping & Lawn Care 1 10-16-2011 08:21 PM
Attaching porch railing to brick wiz561 Building & Construction 0 06-19-2011 01:39 PM
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 08:50 AM
Attaching Porch shed roof to Brick Veneer ApexTiger Building & Construction 46 02-16-2010 05:28 PM
Attaching Deck to Brick Home stubits Building & Construction 1 08-12-2009 11:54 AM
