Attach A Wooden Drink Well To A Granite Bar Top? - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-30-2011, 02:06 PM   #1
Attach a wooden drink well to a granite bar top?
I'm doing some work for a restaurant that wants to add a wooden drink well to their granite bar. I'm going to have to install this on the bottom side of the bar top and was wondering if an adhesive would be enough to hold it or if I need another way to secure it. The bar tenders will be using this well to make drinks in so ti does not need to hold much weight.
rfemali is offline   Reply With Quote
Old 09-30-2011, 02:54 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Bottle well? How many bottles?
Old 09-30-2011, 04:21 PM   #3
kwikfishron's Avatar
Rewards Points: 576
You say it won’t hold much weight but you should mount it as if it will. Bartenders, especially busy ones will punish the thing and don’t care how it’s mounted but it better hold.
A few more details would help. Post a picture or two. How to attach a photo to a post
kwikfishron is offline   Reply With Quote
Old 09-30-2011, 05:27 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You say it wonít hold much weight but you should mount it as if it will. Bartenders, especially busy ones will punish the thing and donít care how itís mounted but it better hold.
That's entirely true. A Liter of liquor will probably weigh around three pounds including the weight of the vessel and when tossed into a well in a high speed operation that bottle will probably hit the holder at almost twice that weight. Then the other static vessels weights just sitting there have to be considered also.
In college I worked as a bartender in a fast track nightclub and we abused those drink wells pretty good. I'm not sure wood is even a good idea but with your sketchy information who knows.
Old 09-30-2011, 05:38 PM   #5
DIY staff
Rewards Points: 7,174
I'm thinking the OP is looking to add a lower glass rail to the bottom of the counter--
Not to hold bottles but glasses for mixing ----
Two part epoxy will hold--however, the glass rail may need to be made of a NSF approved material like Corian or the health department may demand it be removed.
Old 09-30-2011, 05:40 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Okay...that would make more sense. And, you are correct, that is called a "rail" not a well as far as I know.
Old 09-30-2011, 05:55 PM   #7
Rewards Points: 576
Some would even stand on the thing to get up on top of the bar to hang some stupid decoration on the ceiling.
I’ve maintained a few bars and learned quickly to take a bulletproof approach to everything, and even then they still find a way to break it.
Old 09-30-2011, 06:33 PM   #8
DIY staff
Iíve maintained a few bars and learned quickly to take a bulletproof approach to everything, and even then they still find a way to break it.
I've mixed a few drinks in my day---I know all about humans--alcohol and building products--
Is this a lousy granite installation? timbo59 Kitchen & Bath Remodeling 70 05-16-2013 10:08 PM
Best way to attach wooden girders to concrete piers? danf26 Building & Construction 5 05-27-2011 11:30 PM
How do I attach wooden frames to brick wall? martinbudden General DIY Discussions 11 03-09-2011 07:54 AM
Stonemark & Silestone Countertops......??? DepotDweller Remodeling 9 06-25-2009 11:44 AM
what would you use to attach a granite vanity top to the vanity Quadfam4 Remodeling 3 04-30-2009 10:35 PM
